Advantages of a 4.6L Modular over a 5L pushrod.
Old 12-21-2008, 09:34 AM
Jfsram
Jfsram's Avatar
Default Advantages of a 4.6L Modular over a 5L pushrod.
Which is a better engine?
I think the aftermarket and the lightweight of a pre 93 Mustangs have made the 5L's stars in most peoples eyes but are they all that?
Your thoughts.
Jfsram is offline
Old 12-21-2008, 10:22 AM
defconfire
defconfire's Avatar
Mod engines really aren't that great, Not enough aftermarket. The 2v's are really a joke without some sort of F/I
The 4v's are really rev happy and they make pretty good n/a power.
defconfire is offline
Old 12-21-2008, 10:23 AM
SHO NO MERCY
SHO NO MERCY's Avatar
The aftermarket is quite large for the fox. In terms of aftermarket I think the 4.6 has its own advantages over the 5.0 such as forced induciton. Since F/I is becoming more realistic and available with today's technology I think it's easier and cheaper with the birth of centri superchargers to have your 4.6 blown then it ever was for a 5.0.
The fact that the 5L have a single cam and pushrods could be seen as an advantage or a disadvantage depending on reliability compared to performance.
From what I understand about 5.0s compared to 4.6s is the way they respond to aftermarket mods. Our 4.6s are a joke in terms of full bolt-on/hp gain ratio compared to the way a 5.0 responds. Then again the 4.6 also comes stock with 260hp, which is more than the 5.0 put out from the factory.
They're really more about what you want. Effeciency and power of the 4.6 or the less effecient, cheaper to mod, meaner sounding, more potential 5.0.
I'm on the look out for a roller 5.0 notch or an sn-95 5.0 for my next project. There's more ups and downs to both motors and someone with more experience can definately ellaborate on my comments, but that's my two cents.
SHO NO MERCY is offline
Old 12-21-2008, 10:36 AM
silverstang1996
silverstang1996's Avatar
Sho no mercy put it very well. If this is a "should i get 5.0 or 4.6" If it's just a question comparing the motors, I'd say go with a 5.0 or 4.6 4v. The 4.6 2v is an expensive motor to mod (so is the 4v but it has better power out of the box), and as the guy above me said, they don't respond well to mods.
5.0=cheap, easy to make power, kinda slow from the start
4.6 2v (99+)=faster from the start, hard to make any well power without F/I which means a lot of spending
4.6 4v= fastest from the start, can make well power N/A or a lot with F/I but is probably the most expensive.
silverstang1996 is offline
Old 12-21-2008, 10:41 AM
Fuel
Fuel's Avatar
https://mustangforums.com/forum/5-0-...-to-5-0-a.html
i made this post in the 5.0 Tech section, might be a good read for u
Fuel is offline
Old 12-21-2008, 01:03 PM
Quicktime_GT
Quicktime_GT's Avatar
stock vs stock a 99+ 4.6 runs better.
It only takes a set of explorer GT40 heads an intake and cam for a 5.0 to waken up quite a bit.
Here's my choices.. If your goal is:
stock 4.6
300rwhp na 5.0
400rwhp 4.6 with blower
400rwhp na 5.0
700rwhp 4v 4.6 with turbos
over 1000rwhp 5.0 or windsor based pushrod
Quicktime_GT is offline
Old 12-21-2008, 02:58 PM
945LSTANG
945LSTANG's Avatar
stock 4.6
300rwhp na 5.0
400rwhp na 5.0
thats also very easy to achieve in a n/a mach 1.
945LSTANG is offline
Old 12-21-2008, 03:00 PM
defconfire
defconfire's Avatar
True, A Mach 1 can achieve those numbers but it'll cost you quite a bit more than a 1987 LX.
Old 12-21-2008, 03:02 PM
945LSTANG
945LSTANG's Avatar
agreed
Old 12-21-2008, 03:08 PM
boduke0220
boduke0220's Avatar
can you really get 400 hp na with a 5.0?
boduke0220 is offline
Quick Reply: Advantages of a 4.6L Modular over a 5L pushrod.
