Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 12-26-2008, 12:49 PM   #1
LynnBob Mustang
LynnBob Mustang's Avatar
Vehicle: 1999 GT
Default Home tinting my windows
I'm going to giving my own window tint a try for at least my front and side windows.
This is a question for you guys that have your windows tinted already...
When I cut the window tint out for the side door windows should I make the tint go under the rubber door weather strip or should it be cut even with the top weather strip, but not go under it?
The rear sides look self explanitory, just cut enough tint to cover the exposed window but not go under the interior trim, correct?
The back window I may leave to the professionals.
Lynn
__________________
'99 GT automatic
CDC Shaker scoop, K&N Filter
MAC cat back
Max Speed 1 ˝” Lowering springs
KYB GR2 shocks and struts
Cobra front brakes
'65 Mustang coupe in progress
LynnBob Mustang is offline   Reply With Quote
Old 12-26-2008, 12:55 PM   #2
carlastang
2003 Ford GT
Vehicle: 2003 Mustang GT
never done it myself, but have had every single vehicle I've owned tinted. and in my opinion it should definitely go beyond the weather strip as far as you can get with the razor. Remember, it will tuck under the strip inside the vehicle and disappear. Otherwise you will see the edge of the tint.
__________________
03GT
carlastang is offline   Reply With Quote
Old 12-26-2008, 01:01 PM   #3
LynnBob Mustang
Vehicle: 1999 GT
Thats kind of what I figured, but wanted to make sure.
I thought if it was on top of the weather strip you would see and it would also create an edge for which to catch and pull up the window tint.
Thanks,
Lynn
__________________
'99 GT automatic
MAC cat back
Cobra front brakes
Old 12-26-2008, 01:07 PM   #4
HateWhatOwnsYou
Vehicle: 2003, ford, mustang GT
theoretically it should go under the weather strip. i just tinted my windows 2 weeks ago and i couldnt get it to slide under the weather strip. so i said f it, it will still be fine and you cant see the bottom of the tint.
__________________
HateWhatOwnsYou is offline   Reply With Quote
Old 12-26-2008, 01:20 PM   #5
LynnBob Mustang
Vehicle: 1999 GT
Did you cut the tint so it was bigger then the over all window then cut it down after you squeeged it down?
How did you do the back window? Was that a pain in the butt?
I have seen precut window tint for our cars at Avanced auto and thought about getting that and trying the back on my own.
Over all how was it to do?
Lynn
__________________
'99 GT automatic
MAC cat back
Cobra front brakes
Old 12-26-2008, 01:54 PM   #6
HateWhatOwnsYou
yea i cut the tint about an inch bigger, and i tried to slide the tint down, but the window strip was just to tight against the window and wouldnt let it go past.
the front windows and 2 small rears were a snap. i also did a stip across the front window. the only problem im having is that the dot matrix's hold the tint up. when i put it on there was not a single bubble, after a couple days the tint started pulling up and it wont go back down. it doesnt look bad like bubbles do tho
the rear window im not touching, im not even going to pull the old tint off.
__________________
Old 12-26-2008, 05:26 PM   #7
Trob
Vehicle: 00 Performance Red Metallic Mustang GT
Coming from someone who tinted windows for 2 years. If you are going to have the back tinted profesionally, just get all of them done the right way. Its only about 120 bucks for our cars, and from a good shop that will be a lifetime warranty. If youve never tinted windows before, you might not want to start with your car. Because if you mess up, its going to run you about 70 bucks to get it profesionally removed. Last time i tinted someones windows it cost them about 60 bucks for the tint, IMO just get it done the right way the first time. But if you know how to tint and your good at it go for it. The tint should go under the weather strip.
__________________
00 black GT: SOLD.
New Car. 00 Performance Red Metallic GT. Eibach Sportlines. BBK o/r H. Bassani aft-catback. BBK CAI. 3.73 gears. Pro 5.0 Short Throw Shifter. 17 Chrome Saleens. 15% window tint.
Trob is offline   Reply With Quote
Old 12-26-2008, 06:49 PM   #8
0440thgt
0440thgt's Avatar
Vehicle: 2004 Ford Mustang GT
When I was in high school I tinted the windows in my old Chevy truck.
I had NO IDEA what I was doing. I took pieces of cardboard and made templates and transferred them to the tint before cutting it out. Overall, it turned out extremely well. I took my time and enjoyed the process.
I'll take my Stang to the pros though. Like mentioned above, it's only about 100 bucks and if my memory is correct, I spent about 60 on tint for the truck and that was 6 years ago.
__________________
2004 Mustang GT
Black on Black Leather
5-Speed with White Hurst Shift Knob
Anthracite/Polish Bullitt Wheels
Set of weld in Cherry Bomb Extreme 1 Chamber Mufflers with Pypes Offroad X-Pipe
Many many more mods to come!
0440thgt is offline   Reply With Quote
Old 12-26-2008, 07:56 PM   #9
GregElliott
Vehicle: 2003, Ford, Mustang GT
when the shop tinted my windows, they pushed the inside weather strip down into the door as far as possible, put the tint on, and then left the weatherstip like that... then several days later when it was dry enough to roll down the windows, when I rolled em back up the weather strip came back up to its normal position.
GregElliott is offline   Reply With Quote
Old 12-26-2008, 08:12 PM   #10
01snake
2001 Ford Mustang
Vehicle: 2001 ford cobra
for the top:
if your good enough..i have only done it a couple times. when you get the tint on the window the extra you take a razor and trim it off. this is extremely hard, takes alot of practice. but if doen right your whole window will be covered with tint.
NOW, the much easier way..
-clean window
-roll down window ~4"
-cover window (leave ~3" tint overhang)
-trim the excess tint off with a razor blade following the window edge
-TRICKY PART whole tint piece down just under the edge of the window
-continue to squeege the window and roll up and finish bottom
for the bottom:
-after you finish the top part of the window roll it up
-cut ~1/2" extra at the bottom
-peel back the weather strip and tuck the tint GENTLY down
-take a squeege and stick it in there and get out all the excess water
-let go of weather strip
NOW..some will cut it just above the weather strip. but im not a fan of that.
#1 it looks better tucked itno the weather strip
#2 if done properlly you wont have to worry about it getting snagged up on it and peeling off
if it was me i would just take it to get professionally down. ive tinted 5 cars.(some my own, and other for friends). i can gurantee you will burn threw more rolls of tint then you can imagine if its your first time. you will mess up and get fingers, or have missed hairs or particles you did no clean off good enough.
back windows i have yet to do but know what needs to be down as far as shrinking, these are the hardest. if you cant do the 2 front windows dont even bother.
IF you go to put a tint strip on, most of the time you will need to heat shrink the tint to follow the curve of the glass. i would not recommend doing this. because the windshield is 2 pieces of glass and if one gets hotter then the other.......crack
just my .2
have fun, but it will take time
__________________
2001 True Blue Cobra.....it moves...or should i say it did
blown tranny...waiting for a built C4 swap
01snake is offline   Reply With Quote
2001, 2003, back, convertible, cost, default, ford, mustang, put, strip, tint, tinting, truck, window, windows
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
