2000 lincoln continental 4v motor: Will it fit?
just found a 2000 lincoln continental 4v motor for really cheap. Only has 63K on it. Was wondering if would be a possible swap into my 2004 gt. Looking to buy this within the next 24 hours. Input as soon as possible would be greatful thanks.
- CORY
- CORY
found an article where it said bell housing mating was different and motor mounts where different, as well as oil filter and starter being on the wrong side. I think the best bet for straight swap would be a mark engine. This brings me to my next question. Are the continental heads relatively the same as the cobra/mark heads. I am assuming that the heads all share the same bolt pattern and accessory bracket mountings. Just want to be 100% sure. This motor is so cheap that even if it isnt an engine that will swap in if the heads will work then i will still buy it. Thanks a lot for any of your input. Havent dealt with the ford family a lot so im kinda new to this all.
OK, go here http://mustangboards.com/modular-4-6...you-opine.html
If you have questions talk to redneck.
First same motor mounts
Second you will need a new hood because the motor wont clear.
This swap is identical to a cobra R so it will fit, however they say that the 4v is a really really tight fit.
How cheap are you finding the motor?
