Check Engine and Low Oil lights on... Help??
Old 02-01-2009, 02:25 PM
mik3v
mik3v's Avatar
Default Check Engine and Low Oil lights on... Help??
I have a 96 GT. Recently the check engine light came on and then after I changed the oil, the low oil light came on? What do i do?
My dad and I went to Advance Auto Parts and borrowed their Code checking thingamabob. We accidentally cleared the codes and the check engine light went off but not the low oil light. Then shortly after, the check engine light came back on... So now, both lights are still on...
What should I do?
Thanks, Michael
mik3v is offline
Old 02-01-2009, 04:10 PM
Fstanggt96
Fstanggt96's Avatar
hey when you park your car do you park it down hill? in our cars if you park it nose first down a hill the low oil light will come on even if your not low on oil, mine does it every time.
Fstanggt96 is offline
Old 02-01-2009, 07:32 PM
mik3v
mik3v's Avatar
i don't... It is perfectly level when parked at my house and the lights stay on all the time...
oh and about the oil, it has the perfect amount and is new oil...
mik3v is offline
Old 02-01-2009, 09:33 PM
MAD SVT
MAD SVT's Avatar
just try disconnecting the + side of the battery, then touch the + battery wire to the body and let all the juice outta the car (use a screwdriver to arc it if it wont reach if you have to) this should reset it... if it comes back on then its not a false read.
+.... confirm +..... i dont want you to blow yourself up by doing this with the - side haha.
sorry about your pre set programmed radio stations.
MAD SVT is offline
Old 02-01-2009, 11:36 PM
SVTeeshirt
SVTeeshirt's Avatar
^ if that doesn't work, check ur oil again.. sometimes a car will burn a little oil when changed esp one that old.
SVTeeshirt is offline
Old 02-03-2009, 11:02 PM
mik3v
mik3v's Avatar
Alright Thanks guys.
I got the "Low Oil" light to go off... I knew i had plenty of oil, checked the dipstick frequently, so I started ignoring it. Then, my friends and I were doing donuts and zippin around the mall parking lot when the low oil light went off... haha...
Now, just the check engine light is on. I am going to try what Mad suggested with disconnecting the battery tomorrow, thanks guys.
mik3v is offline
Old 02-03-2009, 11:35 PM
Pohatu18
Pohatu18's Avatar
Nice sig pic mik3v I do that going down my streets in the neighborhood all the time. well not anymore since the snow is gone.
Pohatu18 is offline
djbigskrilla
09-20-2022 01:04 AM
ShaneB26154
35
03-04-2021 04:05 AM
labudski
08-24-2015 07:23 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
Quick Reply: Check Engine and Low Oil lights on... Help??
