Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-20-2009, 05:52 PM   #1
jvog
Vehicle: 2002 Mustang GT
Default mt et streets and mt et street radials
What's the difference..I bought my streets thinkin they were the same and they are def different
jvog is offline   Reply With Quote
Old 03-20-2009, 06:29 PM   #2
72MachOne99GT
1999 Ford Mustang
72MachOne99GT's Avatar
Vehicle: 1999 Ford Mustang GT
Send a message via AIM to 72MachOne99GT Send a message via Yahoo to 72MachOne99GT
The ET Streets are bias ply, and do not have any more than the two grooves right down the center of the tire.
The ET Street Radials have additional grooves from the outside that feed some water for slightly better traction.
Both are good tires, but the Street Radials are probably a bit street friendlier. I ran 17K on the Street Radials and cut a 1.85 at the track on a stock suspension.
__________________
'99 GT-5sp.
4.10's, O/R H, catback, MT's
13.6@100 1.8 60'
72MachOne99GT is offline   Reply With Quote
Old 03-20-2009, 09:14 PM   #3
tim2002gt
2002 Ford Mustang
tim2002gt's Avatar
Also, I believe the ET Streets require tubes. If you are going to use these tires, don't run a radial tire up front. You will get alot of side to side movement on the rear of the car at the top end of the track.
__________________
11.54 @ 118.15
tim2002gt is offline   Reply With Quote
Old 03-20-2009, 09:24 PM   #4
jvog
i had no idea that they were that different when I bought them. I'm pretty sure the front tires are radials (crappy tires that came with the car so I havent really looked at them)..Will it be dangerous/hurt my times if I run them?
__________________
2002 GT 5-Speed
V1 S-trim: 369 rwhp/361 rwtq
Old 03-20-2009, 09:37 PM   #5
tim2002gt
2002 Ford Mustang
tim2002gt's Avatar
Shouldn't affect your times, but it will affect how your car handles. I can't say for sure it would be dangerous, but it will likely feel kind of floaty in the back end.
If you can spare the coin, get a set of skinny fronts and a bias ply tire to fit it.
http://www.mickeythompsontires.com/s...p?item=ETFront
__________________
11.54 @ 118.15
Old 03-21-2009, 02:06 AM   #6
ZW99GT
Moderator
ZW99GT's Avatar
Vehicle: 1999 GT
You'll just have to get used to the rear end "swaying" back and fourth on the big end. It's pretty scary the first couple times it happens. You don't have to run the bias ply fronts if you get skinnies. Even a radial skinny will eliminate that all together.
But if it's traction you're after, you certainly picked the right tire. The ET Street will hook alot better than the radial. If you were wanting to drive them on the street, you've got yourself into quite a predicament.
__________________
Stock 351W
ZW99GT is offline   Reply With Quote
Old 03-21-2009, 10:08 AM   #7
jvog
I did notice a little swaying but I didnt think anything of it..I dont drive them on the street except to get to and from the track.
__________________
2002 GT 5-Speed
et, radials, street, streets, times
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
