supercharger question
i always see people boosting 10-11 psi out of ther supercharger. i was wondering is that the max you get out of it or is that just the safest?
and if you wanted more boost is that when you just turbo?
cuz my neighbors has a little speed3 and i think he said he's boosting somewhere around 16psi
A supercharger can produce as much boost as a turbo. It all depends on which one you go with. Something like a p-1 can probably be pushed as high as 18 lbs with an 8 rib kit and a small enough pulley. The d-1 can go a little over 20. You could always go with a F-1R and run 25 lbs as well. The turbo makes more power per lb of boost to the rear tires because it doesn't take power to spin it like a supercharger does.
treesloth
09-28-2015 07:03 AM
