OMFG how could this happen?!
#52
Is it safe to even wax it yet? I used some Mg scratch remover and it helped alot. I may break out my clay bar to see if it will pull up some of the paint at the line. Turned out way better than I thought. Keep any ideas coming. As far as the fishing line I did that lol. Like I said..the adhesive didn't rip the paint off...the paint fixed itself to the thin strip of metal on the backing of the molding that helps it keep it's shape. If all else fails I could always replace the adhesive and stick the ugly *** things back on lmao
#53
I would of took a different aproach to fixing it. I would have used touch up paint on a brush and applied thin coats until it fills up to the same level of the original paint, leaving drying/curing time in betwean coats, and then once the paint layers are even with the original paint, wet sand with the highest grit you can find to blend in, then polish and wax. You would still be able to see it, but only from very up close.
At this point, I would look to be a little creative with a stripe graphic that could cover or distract from the line that is left on there now.
#54
#55
2010 Blue Ball Award Recipient
bagh, who cares...
just leave it like that until you have some cash laying around for paint..
after all, you could get hit by a car door now,, and it'll be a sign that you were supposed to wait to get it painted....then everything will be fine..
or,, you could get it repainted, and then get hit by a car door, but i like to be optimistic!
#56
If it gets to the point were you end up painting your doors, also look into how much more you would need to just go ahead an do a two tone paint job on your car... I figure the bigest prep work is the top half of the car were you would have to deal with seals etc. The bottom of the car should be pretty easy prep work. Just somethingto consider.
#57
I don't mind them that much. At least, not enough to risk ruining my paint over. I don't think they are that noticeable.
KingRando
10-02-2015 08:06 AM
