Fog light wiring?
Old 05-19-2009, 08:00 PM
devongarver
devongarver's Avatar
damn, that was easily the best 5 mins of work i have spent on my car yet, thnx for the info!
devongarver is offline
Old 05-19-2009, 08:45 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
I figured all that out without the schematic
Jazzer feels unloved
Jazzer The Cat is offline
Old 05-19-2009, 09:30 PM
mustangman281
Banned
mustangman281's Avatar
Too bad I can't do it right now. My fuse box is not as accessible as the rest of you guys.
mustangman281 is offline
Old 05-20-2009, 05:12 AM
devongarver
Smile
3 cheers for jazzer!
Old 02-02-2014, 05:15 PM
rarert
rarert's Avatar
Default 2013 GT foglights
Originally Posted by cliffyk
Did I hear a bell ring?
Leaving aside that there's no practical reason to have fog lamps and brights on at the same time--there is a relay conveniently placed in the battery junction box (relay #1), named the Fog lamp cutoff relay (makes sense) that does the dirty deed...
This relay is energised when the brights are on or flashed, and when energised it cuts the fog lamp relay's ground circuit, via its pins 3 and 4--so all one has to do is remove that relay and jumper pins 3 and 4 to keep the fog lamps on during bright operation.
Here's what the relay socket looks like:
Pin 3 uses 1/4" spade connector, pin 4 a 3/16" spade. As all that is being switched is the fog lamp relay's coil you can use 18 ga. wire with no problems.
Is there any way to do the same thing with a 2013 GT? In fact, I'd love to have the foglights as my daytime running lights. Have them come on when you turn the key on.
rarert is offline
Old 10-27-2014, 06:59 PM
deweey
deweey's Avatar
Most states don't allow them on with brights
deweey is offline
Ford_Dude
09-15-2015 03:25 PM
jaiidutch
09-14-2015 10:29 AM
cbird1177711
09-03-2015 08:43 PM
amandahchase
09-03-2015 10:09 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Fog light wiring?
