K member installed!!
Old 05-16-2009, 03:46 PM
4.698GT
4.698GT's Avatar
Default K member installed!!
Just got done installing my Pa racing K member and Tubular control arms. Took my and a buddy about 6 hours to get everything buttoned up. I had to grind off the locating pin on each motor mount and move a ground strap on the driver side and some brake lines on the passenger side. All in all everything went good till I got it on the ground. Its sits high was hell now. Anyone have insight on why that might be. Thanks to looking.
Mike
4.698GT is offline
Old 05-16-2009, 04:15 PM
defconfire
defconfire's Avatar
Take some pics of the car, and also try to get some of the actual suspension that way we can see whats causing the ride height issue.
What springs are you running? are they coilovers?
defconfire is offline
Old 05-16-2009, 05:15 PM
4.698GT
4.698GT's Avatar
Eibach Pro kit. Its probably higher then what it is stock or close to it.
4.698GT is offline
Old 05-16-2009, 06:12 PM
JJ03MustangGT
JJ03MustangGT's Avatar
you did lose a lot of weight on the front so that could have something to do with it.
how hard was the install?
JJ03MustangGT is offline
Old 05-16-2009, 06:36 PM
DreamerGT
DreamerGT's Avatar
yeah thats what I was thinking, you lost weight so the front end came up some.
DreamerGT is offline
Old 05-16-2009, 07:48 PM
4.698GT
4.698GT's Avatar
that what i was figure that the lost weight but i didnt think it would bring it up as much as it did. Install isnt that bad. I managed everything but getting the k member up by myself(awkward espicially when you only have a foot or two of clearence)
4.698GT is offline
Old 05-17-2009, 11:05 AM
JJ03MustangGT
how much does the new k member weigh?
Old 05-17-2009, 12:11 PM
H0SS302
H0SS302's Avatar
I dont think weight loss would have THAT much effect on the height. he said its near stock height which means it is over an inch. I can stand on my stock springs and bounce up and down and they barely move. Its gonna take a lot more than 100lbs or so lost to make them decompress like that. Something like a motor being taken out would.
I would just call the manu. and see whats up.
H0SS302 is offline
Old 05-17-2009, 01:34 PM
4.698GT
4.698GT's Avatar
I measured it out and from center of tire to center of wheel well is like 4.5 inches or so. Its a huge gap.
4.698GT is offline
Old 05-17-2009, 02:15 PM
lizzyfan
Underboss
lizzyfan's Avatar
Did not have that problem and went with 4 cyl springs from FRPP C springs
lizzyfan is offline
Quick Reply: K member installed!!
