Quote:
Originally Posted by 945LSTANG
looks a ton better!
how did you go about cutting them out?
a dremel with the metal saw off attachments.. it took about 2 hours to do bc we had to make 4 combined cuts bc the dremel wouldnt go into the tip all the way to make one big cut... plus, the dremel was overheating or something. it was getting too hot to hold!
after we cut it, the bare metal was showing. Since we were spraying my friends brush guard, we sprayed the inside of my tail pipes with black spray paint.. the rest of the blackout shall come from exhaust fumes
__________________
Things to do:
1) Fix exhaust leak
2) Remove isolators
3) Get rear decklid shaved and painted
DONE
4) Get fog lights sprayed with black/clear mix
5) Get lower valence re-sprayed
So far, i'm
1/5....
