Tell me about Nitrous set ups! I'm new to all this..
Old 06-16-2009, 09:39 AM
kc1983
kc1983's Avatar
Default Tell me about Nitrous set ups! I'm new to all this..
This seems like the best way to get the most horsepower/torque per dollar. I will be considering this mod when I get my stang but have a few questions.
Say I want to do a low HP shot. I'm talking 50-70 HP -
Will I need to install bigger injectors?
What other mods are necessary or would you say are a "must have" for a Nitrous set up?
How much does it cost to refill a Nitrous Oxide bottle and where do you typically get it done at?
Which kits are most popular around here for 2V 4.6 new edge motors?
kc1983 is offline
Old 06-16-2009, 10:03 AM
CAMDUP
CAMDUP's Avatar
http://www.nitrousexpress.com/produc...ils.php?id=950
http://www.nitrousexpress.com/produc...ls.php?id=1357
http://www.nitrousexpress.com/produc...ils.php?id=640
you will not need injectors/fuel pump/re-tune AS LONG AS you keep it at 100 shot or lower....as far as filling bottle,most speed shops do,but i couldnt tell you how much it is these days
CAMDUP is offline
Old 06-16-2009, 10:17 AM
ChalknCover
Sgt. Killjoy
ChalknCover's Avatar
So that is like $1300 for the parts. Not too bad, still cheaper than super or turbo charging.
ChalknCover is offline
Old 06-16-2009, 11:41 AM
dimebag
dimebag's Avatar
Prolly not even that much... 600 for a kit, 100 for a window switch, and 100 for a heater. That's all you need. And I don't even run a heater. And don't waste your time, make sure it works w the 75 jets, then throw the 100s in it.
Its about 50-60 bucks to fill a bottle. Usually machine shops, speed shops, and the track will fill them
dimebag is offline
Old 06-16-2009, 01:27 PM
kc1983
kc1983's Avatar
Awesome. Thanks dudes.
kc1983 is offline
Old 06-16-2009, 04:03 PM
GTRACER88
GTRACER88's Avatar
Harris speed works and dynotune nitrous kits are good for cheaper than zex or Nx. If you get a wet kit you dont need new injectors or fuel pump. It cost me $27.50 to fill up my 10 lbs nitrous bottle.
GTRACER88 is offline
Old 06-16-2009, 05:04 PM
dimebag
dimebag's Avatar
Lucky you, its 50 to 60here
dimebag is offline
Old 06-16-2009, 08:44 PM
01GT4.6
01GT4.6's Avatar
Default read this
https://mustangforums.com/forum/4-6-...-n2o-info.html
01GT4.6 is offline
Old 06-17-2009, 02:11 AM
steedondubs
steedondubs's Avatar
$27 sounds great! Cost me $40 every fill. $1300 is way to high of an estimate. My NX plate kit with window switch and Zex purge was only $900 Installed. SCREW A BOTTLE HEATER! Instead of spending 150 on a heater spend $5 on two Map Torches that last for months. IF YOU KNOW WHAT YOUR DOING
steedondubs is offline
Old 06-17-2009, 08:41 AM
kc1983
kc1983's Avatar
So if I go with a wet kit I don't need injectors, but I will need new injectors on a dry kit?
Whats the biggest benefit to a wet kit? Is it more expensive and harder to install?
kc1983 is offline
Quick Reply: Tell me about Nitrous set ups! I'm new to all this..
