find number 1 cylinder, pull plug put something in the hole, something long, turn crankshaft, when the piston reaches peak of its rotation you are at TDC.
Depends on what your doing that you need to find TDC. There are fast and easy ways and there are exact complicated ways.
I am swapping my heads/cams/timing stuff over to my forged shortblock. I need to find TDC on my old motor, take everything off, and put it on the new shortblock which would also need to be at TDC.
Just take the stuff off no need to put anything at TDC. The only time you need to put the engine at TDC is if you are degreeing the cams with a degree wheel.
Really? Doesn't the new engine have to be at tdc when I put the stuff on? Now I am confused lol. If you could explain to be what I have to do that would be great.
The mark on the crank has to be pointing up. Matching the old engine and new engine's piston positions isn't going to help anything. As soon as you take the timing chains off the cams are going to pop to the closest position where there isn't and pressure on the springs, so you'll have to re-time the cams regardless of where the pistons are.
I think Ox has a writeup of assembling a 2v. Pretty sure it's a sticky.
