Who has swapped 3.73s for 4.10s?
Old 06-24-2009, 01:09 PM
MJH78
MJH78's Avatar
think I could get $100 out of my 3.73s which have like...maybe 1000 miles on them?
MJH78 is offline
Old 06-24-2009, 01:57 PM
CAMDUP
CAMDUP's Avatar
i have done what you are thinkin about , and i was glad that i did !!
CAMDUP is offline
Old 06-24-2009, 03:08 PM
dimebag
dimebag's Avatar
I noticed more from 3.73 to 4.10 then from stock to 3.73... Deffinatly worth it, hands down
dimebag is offline
Old 06-24-2009, 03:28 PM
boduke0220
boduke0220's Avatar
most of my friends wish they went 4.10 and have 373's..IMO though if you do alot of highspeed roll racing ( which is bad btw) or plan on getting blown...i would stick to the 373's but if your gonna stay n/a and do dig or roll racing to around 100 then 4.10 or 4.30 ftw
boduke0220 is offline
Old 06-24-2009, 03:44 PM
jRock617
jRock617's Avatar
I'm going to be in a similar situation of switching gears but my case is a little different.
I have 3.73s now and have no problems with them (I like not having to shift into 5th at the track)
I plan on doing a H/C/I upgrade later and i'll probably need 4.10s due to loss of low end torque.
Do yourself a favor and get gears according to YOUR setup, not what someone else tells you to do. Plan it all out and it'll save you money in the long run.
jRock617 is offline
Old 06-24-2009, 09:43 PM
teej281
4.6L Section Moderator
teej281's Avatar
If you are on the fence about gears...go 3.90. Its a perfect middle ground between 3.73's and 4.10's. Little bit better out of the hole than 3.73's but longer pulls than 4.10's. Perfect gear for those of us who found ourselves in this quandry.
teej281 is offline
Old 06-24-2009, 09:46 PM
ct_white_stang
ct_white_stang's Avatar
If supercharging is in your plans I would stick with what ya got. How bad would that suck if you got a supercharger and wanted to go back to 3.73
ct_white_stang is offline
Old 06-24-2009, 10:44 PM
teej281
teej281's Avatar
To tell you the truth, 4.10's with a blower is friggin awesome. My friend took me out in his 10 second termie the other day and he has 4.10's and it is just sick man. It pulls sooooo much harder than stock. So even if the car has a blower, just invest a little bit in suspension parts and you should hook and have an insanely quick car.
teej281 is offline
Old 06-24-2009, 10:54 PM
mestit3
mestit3's Avatar
I had 3.73's and switched to 4.10's... I couldnt feel a bit of difference and the 1/4 times didnt budge. The only difference I could notice at all was that I would be doing couple hundred more rpm on the hwy.
mestit3 is offline
Old 06-24-2009, 11:06 PM
99BlackPonyGT
aka 'Negative Nancy'
99BlackPonyGT's Avatar
you were riding in a 10 second car....you cant really compare that to a bolt on gt with 3.73s or 4.10s lol
imo, theres better ways to spend your money than to switch from 3.73 to 4.10
99BlackPonyGT is offline
Quick Reply: Who has swapped 3.73s for 4.10s?
