Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-27-2009, 04:11 PM   #1
HaneyMotorsport.Com
Premium Sponsor
HaneyMotorsport.Com's Avatar
Vehicle: 07' Mustang GT Supercharged
Thumbs up New Product from Sniper - Data Scout !!
Hey everyone, I wanted to introduce the newest product from Sniper Delta Force Tuning....
DATA SCOUT!
The Data Scout is a wireless OBDII data logger and scan tool. Best part, it works on all model vehicles that are OBDII (1996 up)
You can read more about it here and see more images. Any questions, please let me know.
Sniper Data Scout
Casey
__________________
HaneyMotorsport.Com is offline   Reply With Quote
Old 06-27-2009, 05:08 PM   #2
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
Vehicle: Stock 96 GT
Send a message via AIM to sxynerd Send a message via Yahoo to sxynerd
Looks like I've got something else to buy, lol.
sxynerd is offline   Reply With Quote
Old 06-27-2009, 05:25 PM   #3
ct_white_stang
2002 FORD Mustang
ct_white_stang's Avatar
Vehicle: 2002,Mustang,GT
+1...I am getting this as well. I wonder how accurate the horsepower reading is?
__________________
2002 GT Vert.
Bassani Mid-Length Headers
Bassani X-Pipe
Bassani Catback
Pro-5.0
FR 3.73
Professional Products 75 tb and plenum
JLT Ram Air
Sniper DF Custom Tune
ct_white_stang is online now   Reply With Quote
Old 06-27-2009, 05:31 PM   #4
Aereon
Vehicle: 03 GT
Send a message via AIM to Aereon
Damn=/ Another thing I wanna buy.. I hate you guys lols
__________________
Big corral, very few horses.
Aereon is offline   Reply With Quote
Old 06-27-2009, 11:04 PM   #5
ct_white_stang
2002 FORD Mustang
Can you clear DTC's with it?
__________________
2002 GT Vert.
Bassani X-Pipe
Bassani Catback
Pro-5.0
FR 3.73
JLT Ram Air
Old 06-28-2009, 09:49 AM   #6
cliffyk
cliffyk's Avatar
Yes, it can clear the DTCs (more about this below) I have been beta testing the system for some time now, and have been told I can release some more information. The goal is to provide a useful tool that can be maintained and improved over time.
Here are some other shots and more information about the software.
The OBD2 interface has a 0-5V auxiliary input, user configurable for the input's name (AFR, EGT, or whatever), unit of measure (:1, V, F, etc.) , and can be mapped to the voltage range/slope of the input device,
Here it has been mapped for AFR where 0.0V = 7.35:1, and 5.0V = 22.39:1...
This could just as easily be programmed to display EGT, in units of °F, with 1.00V = 1000° and 2.00V = 2000°.
The software displays selected PIDs (it polls the ECU to see which PIDs are supported, you then select up to 20 to monitor), and will display MPG based on MAF flow and an assumption of 14.68:1 AFR. However if a wideband O2 sensor is connected to the 0-5V input, and the input is named "AFR" then that value will be used in the fuel economy calculation.
The HP estimator uses the weight of the vehicle and acceleration and deceleration times between selected speeds to calculate rwHP and coast down drag HP. The numbers not necessarily be "accurate" (as in "the same") as compared to a dynamometer that directly measures wheel torque--however they are accurately repeatable, allowing performance changes to be determined.
During the test your current speed and a progress bar are shown:
The 0-60 test works similarly:
The available PIDs are read from your car's ECU, you select those you wish to monitor, they will be displayed in the order that you select them:
Active and pending powertrain DTCs are displayed along with their description, possible causes, and diagnostic tips. The codes can be cleared and the SES lamp can be reset with a single click (actually two, as you will be prompted to confirm the action).
All scan activity is logged, log file management is provided:
The first section pf the filename is user configurable, the remainder is the date and time the log was started in the format yyyymmddhhmmss.
Log files are standard .CSV (Comma Separated Values) format that can be read by any text editor, spreadsheet, or even most word processors. You can then use the tools you like most to analyze the data.
One other neat thing, the application's window is fully re-sizable, even all the way out to full screen, with all of the displayed values growing in size so you can see them while driving!
__________________
-cliff knight-
My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
cliffyk is offline   Reply With Quote
Old 06-28-2009, 10:41 AM   #7
ddmsgtr1
Vehicle: '02 GT
Does this mean we can finally datalog AFR and RPM together?
__________________
'02 GT
SLP LM1, Bassani catted X, BBK shorties, BBK CAI, RPMOutlet.com U/D pullies,
Strange 10ways, built 8.8 w/ 4.10s, Nitto 315 DR's, MGW STS
ddmsgtr1 is offline   Reply With Quote
Old 06-28-2009, 11:16 AM   #8
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
How can the A/F be read from the OBD when it's only reading the stock O2's?
Old 06-28-2009, 11:23 AM   #9
cliffyk
cliffyk's Avatar
Quote:
You need a wideband O2 sensor/controller that has a 0-5V output (or 1-2V, or whatever as long as it's in the range of 0-5V--most all wdiebands have such outputs), you then connect this output to the Data Scout's auxiliary input.
The device then reads RPM, etc., from the OBD2 port and AFR from the auxiliary input.
__________________
-cliff knight-
My Mustang
Old 06-28-2009, 11:38 AM   #10
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
So my innovate LC1 will work fine.. That's good.
af, data, device, economy, fuel, log, logger, scout, sniper, software, tuner
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
