Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-01-2009, 01:15 PM   #1
PaintballFreak
PaintballFreak's Avatar
Vehicle: 2004, Mach 1
Default turn rotors or buy new ones?
So I put a deposit on a mach 1 yesterday. Bank is processing the paperwork and if all goes well (no reason it shouldn't but knock on wood in case!) I will be driving back to pick it up on Friday. Expect to see a BIG OL MACH 1 THREAD then but for now I have a serious inquiry for you gurus.
The car is in really good shape except it's in desperate need of a brake job. The steering wheel shakes pretty bad under braking so I assume I'm going to need to do something with the front rotors, not just the pads.
QUESTION: I've heard that the machinable surface of modern rotors is very thin and that turning them will cause them to warp very easily. So should I not even bother with turning and just buy new ones?
I want to buy OEM quality/performance rotors UNLESS there is a better alternative that doesn't cost what brembo does. Please give me some good suggestions brands and on vendors that have good prices on them. Remember this is a mach 1 so I don't need calipers, just rotors (and I'll take pad suggestions while you're at it). Thanks guys
JD
__________________
1999 GT - SOLD
2004 Mach 1 - Azure Blue
BBK Long Tubes - MAC O/R Prochamber - Borla Stingers
4.10s - Sniper Tuned
PaintballFreak is offline   Reply With Quote
Old 07-01-2009, 01:33 PM   #2
02 Ninja
2002 Ford Mustang
02 Ninja's Avatar
Vehicle: 2002 Ford Ferret
Send a message via MSN to 02 Ninja Send a message via Yahoo to 02 Ninja
If you have the money, just get some new slotted rotors. Take a road trip down to waco to Latemodel Restoration and pick em up. If you decide to go, pm me and i'll meet you there and then it's hooters for a beer.....or two.
__________________
Defensive Driving Is For Those Who Get Caught
Falling down 4 flights of stairs..When that clothes hanger just wont work!
02 Ninja is offline   Reply With Quote
Old 07-01-2009, 01:46 PM   #3
PaintballFreak
I didn't know LMR was in Waco.. I may have to take you up on that! Let's see what else we can find though
__________________
1999 GT - SOLD
Old 07-01-2009, 05:39 PM   #4
youkairyu32
youkairyu32's Avatar
Vehicle: 04 GT/Mutt
The difference between turning and buying new rotors is fairly simple. Turning the rotors the first time or two shouldn't cause any trouble, so there is no reason not to. However, depending upon the type of breaks that you currently have it can actually be kind of dumb. For example, I have seen new rotors from Kragen cost almost exactly the same as having the old ones turned. In that kind of scenario, why not just buy the new ones?
When it comes to performance brakes, you can get drilled/slotted rotors which will keep your brakes cooler under heavy breaking conditions. That seems like it would be when turning rotors would become beneficial. The cost of turning rotors has stayed the same as the OEM ones, however the cost of new ones has gone up.
If I were you I would check out Bear brakes and get some cross drilled/slotted rotors. They are sold all over the place, you shouldn't have trouble finding them.
With regards to the brake pads... what ever you do don't go with the full ceramic race pads that they put on like corvettes and stuff. I thought it would be rad so I spent umpteen number of dollars on them... they are supposed to work well at high speeds. And they do, but what they failed to mention is that they only work well at high speeds. I don't start to feel real performance out of them until I am over 100 MPH. Just cruzzin around town or at basic 55 mph freeway speeds, it feels like your pads are wet. You know, like when you just get out of the carwash and attempt to stop the car. It sucks. Make sure you go with street pads, or at the very least a dual purpose pad.
youkairyu32 is offline   Reply With Quote
Old 07-01-2009, 06:55 PM   #5
H0SS302
2001 Ford Mustang
Vehicle: '01 GT Vert;
Send a message via AIM to H0SS302
Why dont you get the dealership to replace them for you? They shouldnt sell you a car with bad brakes. If its a private seller have them knock off the cost of new rotors.
just my .02 on that.
if the rotor thickness is within spec turn them, no need to buy new.
__________________
Corner Carving > All
H0SS302 is offline   Reply With Quote
Old 07-01-2009, 07:56 PM   #6
SilverNGrey4.6s
Vehicle: 02 Ford Mustang GT and 03 Crown Victoria PI
yeah that
__________________
2003 Grey Crown Victoria Police Interceptor the DD stock
2002 Silver Mustang Gt not stock
JLT Cold air intake
Accufab 75mm Throttle Body & Plenum
Mac longtube headers
Dr.Gas o/r x
SLP Loudmouth 1
3.73 gears
Steeda tri ax short shifter
H&R sport springs
Tokico HP Shocks & Shruts
18x9/18x10 Black chrome bullitt rims
SCT Xcal 2 tuner done by JMS Chip and perf.
http://Centraltexasstangs.com
SilverNGrey4.6s is offline   Reply With Quote
Old 07-01-2009, 09:42 PM   #7
2000AZ5.0GT
2000 Ford Mustang
Vehicle: 2000 Ford Mustang GT
Aren't the Brembo rotors like 140 for two of em (stock replacements?)
Baer wants like 240 for two, total crock
oh, an unless you're racing, I think that the slotted will actually wear your pads more
If it's pulling from side to side under breaking, you need to rebuild the front calipers, and grease the crap out of the pistons when you put them back in, they're sticking.
It's not the pads, it's the actual calipers.
__________________
Quote:
Originally Posted by Rdot9 View Post
i could go for a nice can of cock rite now actually...
2000AZ5.0GT is online now   Reply With Quote
Old 07-01-2009, 10:55 PM   #8
04CompetitionOrange
04CompetitionOrange's Avatar
I agree with Hoss and SilverNGrey. Get the seller to take care of the issue before the pawn it off on you.
__________________
2004 Competition Orange Mustang GT
99/01 Cobra Front Bumper, Pypes O/R X pipe, Pypes Violator Cat-back
04CompetitionOrange is offline   Reply With Quote
Old 07-02-2009, 02:04 AM   #9
gunpig0313
gunpig0313's Avatar
Vehicle: 04 Mustang GT
Send a message via AIM to gunpig0313
Clean and lube the slides also if you do the brakes your self.
__________________
04 GT Screaming Yellow
K&N cold air, 24# injectors, SCT tune, SLP X-Pipe, Spin Tech cat back, Hurst shifter, 3:55 gears, & a couple of Autometer gauges.
03 Aviator Ivory Pearl
Stock for now
gunpig0313 is offline   Reply With Quote
Old 07-02-2009, 10:44 AM   #10
Furinox
just turn them if you want to save money. o'reilleys turns rotors for like 6 bucks each.
__________________
________________________________________________
Just some bolt ons and bolt ins by Manley, JE, and Vortech.
Furinox is offline   Reply With Quote
austin, brembo, buy, california, cut, drilled, evolution, kragen, machinable, rotor, rotors, slotted, turn, turning, tx, uneven, wear
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
