And these gains are over fox lake stage 2 heads...so that alone speaks worlds for these heads because fox lake makes some awesome heads from what ive seen. Just for anyone who didnt read that part of the thread.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
2002 Mustang GT Conv: PYPES O/R X, Flowmaster catback, JLT cold air intake, FRPP 4.10's, Xcal 3, Strange 10 way Shocks and Struts, Eibach Pro-Kit, UPR C/C Plates, and Steeda Tri-Ax with Hurst black ball shift knob, 03/04 Cobra bumper....250rwhp, 263rwtq(with slipping clutch)
For a fully built 2v to put down only 305rwhp and 316rwtq isnt that great. And to gain 50rwhp over that number by just doing these heads id say is impressive. And the fact that the power starts out the same and grows gradually over the entire rpm band says a lot about these heads that they dont just make peak power but broaden the hp and torque curve overall which is an awesome feat in my opinon. I would like to see a direct swap from completely stock to these heads and some custom grind cams to see how the power curve and drivability would be affected by these things. I always had extreme faith in these heads and I think after seeing these results, I feel I was right.
The car obviously can put down more than 305 rwhp, but in auto-x there are classes and strict regulations. The class the guy runs in has a strict hp/weight ratio so he had to detune it to qualify.
Well if he was running an 11:1 compression with ported heads and cams, why didnt he just do lower compression and not as much cam??? I mean why have all that available and have to detune the car to get it to where you want it to be??? Id say build it to where you want it to be and have it be tuned to full potential to run it. But thats just me.
__________________
I would go ahead and say it probably not an upgrade for the 4v guys. This is likely a fairly heavily cammed car.. 99-01 cobras can get to the 320 rwhp range with full boltons and with cams can hit around ~370-380 rwhp.
Besides the 4v's tend to make much more linear power than the 2v's which can be good for some applications.
I'd say if you have a 4v keep it a 4v and just add some cams if you still want more n/a power.
You are pretty wrong on a few of the things you said..
2vs ussually make more average power...
4s ussually make more peak...
You will never ever ever ever ever ever make 370 or 380 in a cam only 4v....
350 being the max.. most being in the 330 340 range..
most full bolt on 4vs make 300ish...
the freaks all out ones making 320..
__________________
"If people are calling BS, you know your doing something right."
11s with no 3rd gear.
http://s104.photobucket.com/albums/m199/blackonblacksls/?action=view¤t=MVI_1493.flv
So what was the final compression it says the heads made it pick up another point
__________________
TRADE MY Mach 1 HOOD + scoop set up for easy GT install (attached, no intake system necessary, unless you want it) for a COWL hood and maybe STOCK + CASH (but probably not). The hood is painted silver, in great shape, does need a color sand, but thats no biggie. Would prefer a swap for a silver one, but will consider many options. Need to trade due to changed plan on this car. RTP/Greensboro/Charlotte
Im wondering how much power a car would put down with full bolt ons, these heads ported, a better intake manifold, and cams better suited for these heads.
do you guys really think we'll see 390 hp N/A?????
I mean if this car made 350 to the wheels and it had the stock PI intake and unported TFS heads and a cam that wasnt specifically for the heads, do you think we'll see close to the 400 mark?
__________________
Silver 2002 Mustang GT
BBK Long Tube Headers, BBK H-Pipe, Magnaflow Magnapack Catback
Not to the wheels
__________________
Tuned by Matt at Performance Evolution
432 rwhp
426 tq
i bet they can coax another 25 hp out of it..maybe more idk..depends on the porting because arent the combustion chambers too narrow so to port the heads more you gotta bore it out too? not sure if thats true but i heard that as well...
