BEST UPGRADES FOR MAXIMUM HP GAIN
and now that i think of it.. if you get all that little stuff now, all your doing is postponing the supercharger/turbo, because all in all after all that is said and done and you've bolted on the last bolt..on you will then look for more, like well all do, and that will be the next step.
Say you get a kenne bell. you dont need a plenum. so if you buy one now, you just p1ssed say $200(dont know actual price) away for nothing... Get it. Just like underdrive pulleys, if you go with a blower, they have to come off the engine. you cant run U/D pulleys with a blower. thats another $200 p1ssed away in the wind..
Thats why you should buy the blower first, then add to it. This way you know you can use the parts you are buying with whatever setup you are running at the time.
It's up to you on what you want to do, i'm just trying to save you money. BTW, most ppl running a KB blower make 380 or so RWHP through the stock TB.. so restriction is really not a big issue on the stock TB
You won't gain anywhere near that with a throttle body and plenum. 2v's don't respond well to simple bolt ons. It take alot to gain some power out of the 2v's such as Heads, Cams, Supercharger or Turbo.
LoL
I use to have a 2001 GT as my first mustang so I know how hard it is to try and get power out of a 2v without having to spend a ton of money.
That's why I always tell people if they can save up a little more moeny and go with a cobra or a mach if you want to stay in a mustang but if you don't mind f-bodies, a LS1 is where its at.
