Trick flow cams duration 264/264 lift .550/.550 review??
lookin to get the spring set stage one camshafts and springs.
am i going to need to upgrade the gears and fuel injectors as well.
i need some HELLPPPP please.
Yes, the timing gears that are connected by a chain to the crankshaft to keep the cams turning at the same rate as crankshaft so your valves dont hit the pistons and cause a motor meltdown. And i read your sig...muffler delete with longtubes is gonna sound horrible. Just food for thought. Your injectors should be fine. Friend running stock injectors with a 125 shot of nitrous and no problems so stage 1 cams should be fine. as for rear gears, there are 2 main choices that everyone suggests. 3.73's and 4.10's are the most popular ratios. 3.73's are good for boost or planning on boost but most people that are not gonna run boost go with 4.10's. I went with 4.10's and they rock!!! They are so much fun. Makes the car a lot more enjoyable. So for you, i'd say go with 4.10's seeing as that cam looks to be an n/a cam.
thanks alot ive had many mixed reviews on headers im lost on those, but yeah im staying all natural so i will most like end up with the 4.10s and im installin the cams myself with my buddy he has a cobra stage 2 camed so hes gonna help. but would you reccomend shorty headers?
Long tubes or bust.
