stock fuel pump
Old 08-02-2009, 05:20 AM
WhiteNoise
WhiteNoise's Avatar
Default stock fuel pump
will the stock fuel pump support a 150 wet shot? i have been told not to worry bout it, but screw that. i need closure!
i know i should upgrade but if i dont need to right now then i wont.
WhiteNoise is offline
Old 08-02-2009, 07:35 AM
mrtstang
mrtstang's Avatar
All i can tell you is that at 373 rwhp/528 rwtq on a 100 shot, my stock pump was working. I changed it though, because it was working at 100% capacity. Which means the pump was being stressed to the max. That's not a good thing!
mrtstang is offline
Old 08-02-2009, 09:18 AM
dimebag
dimebag's Avatar
I spray 100...and have no problems...
dimebag is offline
Old 08-02-2009, 02:46 PM
BOSTANG
BOSTANG's Avatar
I had a stock pump and was sparying 125 wet. The stock pump work find. Then change the pump out for a aviator pump.
BOSTANG is offline
Old 08-02-2009, 05:35 PM
pcs
pcs's Avatar
+1
you never want to run your fuel pump or injectors at 100% b/c then they can not account for other variable not seen on a dyno such as elevation or big weather changes. just go with a ford gt pump, aviator, or svt focus pump to be on the safe side. a fuel pump is much cheaper than a new engine.
pcs is offline
Old 08-02-2009, 09:45 PM
JayC
JayC's Avatar
Mine would not support a Nitrous Express 150 shot. Some other companies rate their shots differently. I went with a SVT Focus pump.....no worries.
JayC is offline
Old 08-03-2009, 08:34 AM
WhiteNoise
WhiteNoise's Avatar
sweat, thanks for the input guys. i guess ill put a pump on order. till then ill only do a 100 shot.
StalkerGT
09-25-2015 02:41 PM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: stock fuel pump
