Go Back   MustangForums.com > Ford Mustang Tech > 4.6L (1996-2004 Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-05-2009, 12:12 AM   #1
crider4_6
crider4_6's Avatar
Vehicle: 2000,Ford,mustang GT convert
Default T/O bearing
wt is a good throw out bearing???? just put a new clutch in in jan and t/o bearing came apart last night and it was a federal morgal top of the line from the local parts store ??? any help
__________________
car cant be posted here due to not enought post's
perfosinal products plenum and tb 70mm plenum polished inside and out ,sct dyno tuned,242@5400rpm grenitelli coil packs ,24lbs inj
crider4_6 is offline   Reply With Quote
Old 08-05-2009, 12:34 AM   #2
WhiteFoxGT
2001 Ford F-150
WhiteFoxGT's Avatar
Vehicle: 01 Lightning
Ford or bust my man
__________________
RESIDENT FORD TECH
`01 Lightning ----- FOR SALE http://mustangforums.com/forum/other...-for-sale.html
Stiegemeier stage 4 blower. LFP ported intake, Accufab TB, #6 pulley, 60# injectors, MAFia, Art Carr converter, JLP intake + traction bars, Magnaflow catback, AFCO h/e, LC1/XD16, SCT tuned by Matt @ Performance Evolution 448hp/508tq
WhiteFoxGT is offline   Reply With Quote
Old 08-05-2009, 02:05 AM   #3
DeltaV
Vehicle: 2003 Ford Mustang GT
Send a message via AIM to DeltaV
T/O bearing+ New edge= Fail!!!! The end! Mine is going bad to... i can hear it! Oh well... i will get around to changing it out one of these days!
edit
I agree with whitefox, Ford or bust... i have a centerforce in mine and it blows!
__________________
Have a tax question? Call me, the local Mustang Forums CPA!
Cam Videos
http://www.youtube.com/watch?v=VhyPKhFkBks
http://www.youtube.com/watch?v=vv-JKjb3qfk
DeltaV is offline   Reply With Quote
Old 08-05-2009, 08:15 AM   #4
Jazzer The Cat
Wheels/Tires Section Moderator
2002 Ford Mustang
Jazzer The Cat's Avatar
Vehicle: '02 s281 #0014
Go stock and go Jazzer's Super-Duper Magnetico-Retractor system
This will save your bearing from the constant rotation you will find on the stock design. It will also ensure that your cable is not out of adjustment, because you can "feel" its relative position just by using clutch.
Jazzer
Jazzer The Cat is online now   Reply With Quote
Old 08-05-2009, 09:43 AM   #5
Kmelfi11
2002 Ford Mustang
Vehicle: 2002 Ford Mustang GT
Jazzer
i need to do this asap, i hear that damn noise haunting me in my sleep. my car eats them, new one in 2 days later its done...
__________________
Kmelfi11 is offline   Reply With Quote
Old 08-05-2009, 10:28 AM   #6
True Blue Racing
Vehicle: '99 GT Vert
I have the same issue. i have gone thru 4 t/o bearings in my car. I have pulling the tranny out down to a science now.
__________________
True Blue Racing is offline   Reply With Quote
Old 08-05-2009, 12:10 PM   #7
Jazzer The Cat
2002 Ford Mustang
^ The bearing is designed to be "constant rotation" as per Ford. This seems like a VERY bad idea to me, hence my hard-drive magnet return.
This magnet is a VERY easy mod for those with even moddest mech. skill.
Jazzer
Old 08-05-2009, 01:14 PM   #8
Repzard
Repzard's Avatar
Vehicle: 99 Ford Mustang GT
Jazzer
Can you explain ?
Im interested in knowing what this mod is.
TOB in mine is noisy as well , just turn up the tunes
99 GT here
__________________
My cars owned
But really happy to own my 1st Ford
06 Cobalt SS\SC - Gone !! What a POS
93 Corvette 40th - Great Car( Stock )
99 Mustang GT- Upgrades As Followed : Flowmasters 40 , After market H pipe w/Cats , gears 4:10s , Engine is stock but many upgrades to come
New Mods, Tinted rear tail lights,Tinted windows 35%,k&n cai
Quote: If you see my Mustang or Corvette on a trailers.
Call the Police....Its been stolen !!!!
Repzard is offline   Reply With Quote
Old 08-05-2009, 01:16 PM   #9
True Blue Racing
if this current t/o bearing ever goes out i might just try your magnet set up. The one i have in now is actually on its second summer (they used to last about 2 months), but i also put less that 4,000 miles on the car last year too.
__________________
Old 08-05-2009, 01:40 PM   #10
Jazzer The Cat
2002 Ford Mustang
The beauty of the magnet set-up I have made, is not only removes TO bearing from the pressure plate, but can just jack up your ride and install it
What you need is a bad hard-drive from a computer:
See the 1/2 moon flat silver piece at the bottom LH corner? That is one of two VERY strong magnets (the second one is on the opposite side of the plates). Tear a hard-drive apart and remove these bad boys. Be carefull, they will try to stick together in your hands and pinch the bejesus out of your fingers tips and mangle your skin (the larger capacity hard drives have stronger magnets). Next, get a 3/16" (or so) bolt that will fit through the mounting hole of magnet and drill a hole in the trans bell-housing and put the face of the magnet about 1/8" away from the clutch fork. Use a small piece of pipe as a spacer for inbetween the magnet and the bell housing. You can see the magnet never actually contacts the fork, but rather just "draws" it close until cable slack runs out. This will add a slight "snap release" when you place your foot on the pedal and can feel the pull for only a moment. I thought about using a spring, but this would just add additional tension throughout the clutch travel and just fatigue ones leg.
Just watch the vid a few times and can see how it works.
Jazzer The Mad Modder
obering
Similar Threads
NEED INPUT QUICKLY on CLUTCH T/O BEARING joeybutts 4.6L (1996-2004 Modular) Mustang 17 11-22-2006 11:31 AM
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
