Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-09-2009, 04:40 PM   #1
hpwrestler220
hpwrestler220's Avatar
Vehicle: 2001
Default 13.8 mpg?? come in and help me out
Granted i did some spirited driving and i had the AC on for the whole tank of gas, is 13.8 mpg normal??? i usually get like 16.. but i did a whole tank of gas highway and i only got 18mpg and that was cruising around 75 without air conditioning on that tank of gas... WTF is goin on here? car is an 01 5spd with 60k on the clock. do i need a tune up? (new fuel filter, clean out air filter, new spark plugs?)
ALSO, when i first start my car up, it fires up and roars like it should.. but if i drive the car and than shut it off and come back to drive again in an hour or two, the car will start, but it BARELY starts.. it doesnt roar like that first start up... its a guessing game as to whether or not its going to start on me or not... is that a spark plug issue or do you think my battery is running outta juice? bc i can def use a new battery too
AND ONE MORE THING --- if im ripping through first gear and i go to shift into 2nd at like 5000-5500rpm my clutch will make a SQUEALING noise... is that normal? ive heard it is, but i think its time for a new clutch anyway..
__________________
Things to do:
1) Fix exhaust leak
2) Remove isolators
3) Get rear decklid shaved and painted DONE
4) Get fog lights sprayed with black/clear mix
5) Get lower valence re-sprayed
So far, i'm 1/5....
hpwrestler220 is offline   Reply With Quote
Old 08-09-2009, 04:48 PM   #2
SilverNGrey4.6s
Vehicle: 02 Ford Mustang GT and 03 Crown Victoria PI
Clean out the oil filter? It that what you do instead of buying a new one? lol
__________________
2003 Grey Crown Victoria Police Interceptor the DD stock
2002 Silver Mustang Gt not stock
JLT Cold air intake
Accufab 75mm Throttle Body & Plenum
Mac longtube headers
Dr.Gas o/r x
SLP Loudmouth 1
3.73 gears
Steeda tri ax short shifter
H&R sport springs
Tokico HP Shocks & Shruts
18x9/18x10 Black chrome bullitt rims
SCT Xcal 2 tuner done by JMS Chip and perf.
http://Centraltexasstangs.com
SilverNGrey4.6s is offline   Reply With Quote
Old 08-09-2009, 04:52 PM   #3
hpwrestler220
Vehicle: 2001
Quote:
HAHAHAHA i meant air filter... for all i know its black right now.. i never look at that thing since its in the fender
lmao please excuse me.. long night last night. still not recovered =P
__________________
Things to do:
1) Fix exhaust leak
2) Remove isolators
So far, i'm 1/5....
Old 08-09-2009, 04:54 PM   #4
2000AZ5.0GT
2000 Ford Mustang
Vehicle: 2000 Ford Mustang GT
Could be the battery, but doesn't sound like it. Have it checked out at autozone.
Sounds more like fuel/air filter or plugs. Could be a combination, or could just be one.
__________________
Quote:
Originally Posted by Rdot9 View Post
i could go for a nice can of cock rite now actually...
2000AZ5.0GT is online now   Reply With Quote
Old 08-09-2009, 04:58 PM   #5
a_penquin
1998 Ford Mustang
Vehicle: 1998 Ford Mustang GT
Send a message via AIM to a_penquin Send a message via MSN to a_penquin Send a message via Yahoo to a_penquin Send a message via Skype™ to a_penquin
Sounds like tune up time, I normally pull 25-27 highway. Very possible the start up issue is also related to the ignition system, or fuel system and be covered under the tune up. I also have the high rpm squeak, but someday I hope to get the high rpm tire chirp to dround it out
__________________
98 4.6 SOHC GT
MSD coil packs, Headman street headers, BBK X-pipe w/cats, Cherry Bomb vortex cat back, ZOOM clutch, Auto Meter 3 pillar w/oil press, water temp, and volt gauges, Alpine head unit. work still in progress.
a_penquin is offline   Reply With Quote
Old 08-09-2009, 04:59 PM   #6
hpwrestler220
Vehicle: 2001
when is the time to buy new plugs??? its not like they are expensive so i could prob use some no?
__________________
Things to do:
1) Fix exhaust leak
2) Remove isolators
So far, i'm 1/5....
Old 08-09-2009, 05:01 PM   #7
2000AZ5.0GT
2000 Ford Mustang
I'd say around 80,000-100,000 miles is a good time for new plugs.
also might be the stock CoP's failing when they warmup, I've been through that. shouldn't be if it's a 2003+ model.
__________________
Old 08-09-2009, 05:04 PM   #8
SilverNGrey4.6s
Oh ok thank god, but I would start with air and fuel filters.
__________________
JLT Cold air intake
Dr.Gas o/r x
SLP Loudmouth 1
3.73 gears
H&R sport springs
Old 08-09-2009, 05:05 PM   #9
hpwrestler220
Vehicle: 2001
Quote:
tire chirp is over-rated.. its all about sticking to the pavement =) so what should i do with my tune up???
spark plugs (what kind?) and ill check my compression ratio while im in there
clean my air filter
get a new fuel filter? (my dad says i dont need to bc fuel is cleaner now than way back then?) i feel like i should get one anyway
and im definitely getting a new battery.
am i missing anything?
__________________
Things to do:
1) Fix exhaust leak
2) Remove isolators
So far, i'm 1/5....
Old 08-09-2009, 05:08 PM   #10
hpwrestler220
Vehicle: 2001
ughhh... i dont wanna have to pay for those bad boys... hopefully once i tune her up it will start fine and ill start seeing at least 20mpg on the highway.. 18 is killer
__________________
Things to do:
1) Fix exhaust leak
2) Remove isolators
So far, i'm 1/5....
2001, 20mpg, gt, mpg, mustang, tune
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
