Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-16-2009, 04:06 PM   #11
Mustang_NTriangle
500 rwhp.
__________________
03 Vert 5 speed
450 rwhp
MMR 800 Built Block
CMS 2.5 Blower Cams
Vortech V2 SQ H.O. Aftercooled
12.5 PSI
Sniper Tuned
4 sale - pm me
38lb vortech injectors $150 shipped
21lb injectors $ 50 shipped
Aluminum Intake (replace that plastic intake) $100 shipped
(8) stock Ingition Coils $150 shipped
2004 stock short block 23,000 miles $300 B.O.
Mustang_NTriangle is offline   Reply With Quote
Old 08-16-2009, 09:37 PM   #12
jvog
Vehicle: 2002 Mustang GT
Quote:
Originally Posted by Mustang_NTriangle View Post
500 rwhp.
Are you upgrading your FPDM? It says you have to when using a BAP and focus pump.
__________________
2002 GT 5-Speed
V1 S-trim: 369 rwhp/361 rwtq
jvog is offline   Reply With Quote
Old 08-17-2009, 06:26 PM   #13
Mustang_NTriangle
Quote:
What is an FPDM? I did not consider this.
__________________
03 Vert 5 speed
450 rwhp
MMR 800 Built Block
CMS 2.5 Blower Cams
12.5 PSI
Sniper Tuned
4 sale - pm me
Old 08-17-2009, 09:35 PM   #14
jvog
Fuel Pressure Driver Module
__________________
2002 GT 5-Speed
Old 08-18-2009, 05:49 PM   #15
Mustang_NTriangle
Based on other posts here I will not need it since I just have one fuel pump and a BAP. Since you are looking to do two fuel pumps it is required for your voltage.
__________________
03 Vert 5 speed
450 rwhp
MMR 800 Built Block
CMS 2.5 Blower Cams
12.5 PSI
Sniper Tuned
4 sale - pm me
Old 08-18-2009, 09:43 PM   #16
jvog
I copied this from the Lethal Performance web site
WHEN DO YOU NEED IT?
If you'are running a pair of big returnless fuel pumps (i.e. Lincoln Aviator, Ford Focus, or Ford GT) and/or running '03/'04 SVT Cobra dual pumps with a pump voltage booster in your high-horsepower Mustang you NEED to have your FPDM modified. This modification allows the Ford Mustang driver (99-04) to sink substantially more current (up to 25Amps) without overheating. What happens when the stock driver overheats? It goes into thermal limiting and cuts ALL fuel supply to your engine until the driver temperature drops below a safe level. As I'm sure you're aware, the loss of fuel pressure with your engine at full load can often times be catastrophic!
This modification will NOT require a retune of your vehicle. It will not reduce reliability of the driver or of the system. In fact, the driver will run much cooler than in the stock configuration which will prolong its life even when used with high-flow, high-current dual pumps.
WHEN DON'T YOU NEED IT?
This modification is NOT necessary if you are running stock '03/'04 Cobra dual pumps without a pump voltage booster or a single Aviator, Focus, or Ford GT pump without a pump voltage booster. It will not hurt to do this modification with the above mentioned systems but it is not necessary as those pump setups all draw less than 18Amps at full load.
I bolded the part thats important. You don't need it when you are running a single pump without a voltage booster. Based on the fact that it specifically stats without, one can reasonably deduct that with it you do need a modified fpdm.
__________________
2002 GT 5-Speed
Old 08-19-2009, 06:53 AM   #17
z06saleen
z06saleen's Avatar
Vehicle: 2002,ford,saleenmustang
Quote:
Originally Posted by z06saleen View Post
2002 2v mod motor stage 2 patriot heads and cams. 2.6 liter kennebell 14 pounds of boost. 520rwhp 500ft/lbs.
2002 2v mod motor stage 2 patriot heads and cams. 2.6 liter kennebell 17 pounds of boost. 536.6rwhp 550ft/lbs.
z06saleen is offline   Reply With Quote
Old 08-19-2009, 06:37 PM   #18
Mustang_NTriangle
What are you running for fuel system?
__________________
03 Vert 5 speed
450 rwhp
MMR 800 Built Block
CMS 2.5 Blower Cams
12.5 PSI
Sniper Tuned
4 sale - pm me
Old 08-19-2009, 07:49 PM   #19
jvog
This is my plan. I am going to run dual cobra pumps, w/o a BAP which are good for 460-480 rwhp. Then, when I have the money and get bored with the power I can throw a BAP on it and upgrade the FPDM.
__________________
2002 GT 5-Speed
Old 08-19-2009, 08:05 PM   #20
Mustang_NTriangle
I am going with 1 Focus Pump, BAP and targeting 480-500 rwhp. I just need to confirm my build weekend with my buddy. Let me know how you do once completed.
__________________
03 Vert 5 speed
450 rwhp
MMR 800 Built Block
CMS 2.5 Blower Cams
12.5 PSI
Sniper Tuned
4 sale - pm me
bap, bell, boost, build, focus, ford, fuel, hp, kenne, lmaf, modified, pump, sensor, single, update
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
