Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-14-2009, 09:14 PM   #1
Mustang_NTriangle
Default My Build Update
Well - I finally got the rest of my parts to complete by build. The UPS guys has been a daily occurrence for the past two weeks. My wife is like WTF...
- MMR 800 short block
- Received COMP Retainers for my COMP BEEHIVE Springs
- Mishimoto Radiator
- MMR 7Q Oil Pan
- Engine Stand from Summit Racing
Remaining steps:
Install CMS 2.5 blower cams, springs, and retainers
Pull my blown motor
Swap out parts w/ new 60 lb injectors
Install my new XTD Stage III clutch
MRT Catted H Pipe
Custom Dyno Tune
I cannot wait to hear the cammed sound with the new catted H pipe. Currently, I only have stock H pipe with STEEDA catback. Hopefully this will be done by 1st week in September
Once she is all done I will post up a video.
Keith
__________________
03 Vert 5 speed
450 rwhp
MMR 800 Built Block
CMS 2.5 Blower Cams
Vortech V2 SQ H.O. Aftercooled
12.5 PSI
Sniper Tuned
4 sale - pm me
38lb vortech injectors $150 shipped
21lb injectors $ 50 shipped
Aluminum Intake (replace that plastic intake) $100 shipped
(8) stock Ingition Coils $150 shipped
2004 stock short block 23,000 miles $300 B.O.
Mustang_NTriangle is offline   Reply With Quote
Old 08-14-2009, 09:41 PM   #2
jvog
Vehicle: 2002 Mustang GT
sounds sweet. I'm almost finished too, just gotta get the engine on the hoist, throw the flywheel on, install clutch and bolt the trans back up and drop it in. I have the same clutch by the way
__________________
2002 GT 5-Speed
V1 S-trim: 369 rwhp/361 rwtq
jvog is offline   Reply With Quote
Old 08-14-2009, 09:46 PM   #3
Mustang_NTriangle
Nice JVOG you are almost done. Let me know how you like that clutch and if it much heavier than stock. For me, I have not driven my car in a year and currently driving 2008 Jetta 5 speed my DD so it is going to be a huge difference all around
What motor amounts are you using? I went with MMR solid motor mounts but keeping tranny mounts stock along with tranny for now. What pully size you running? I am going with 3.12". Goodluck with your build.
__________________
03 Vert 5 speed
450 rwhp
MMR 800 Built Block
CMS 2.5 Blower Cams
12.5 PSI
Sniper Tuned
4 sale - pm me
Old 08-14-2009, 10:03 PM   #4
jvog
I just reused my stock motor mounts because they looked fine. I talked to Chris at PAS and he said that they use factory motor mounts in most of their cars. I really need to figure out what fuel system I am going with so I can figure out what size pully I am going to need to make the power I want that my system can support. Any ideas as to the most affordable way to support 500 rwhp fuel wise lol
__________________
2002 GT 5-Speed
Old 08-14-2009, 10:20 PM   #5
Mustang_NTriangle
Well I am using stock heads, 60 lbs injectors, Kenne bell Boost Pump, 1 SVT Focus Fuel Pump, 90 LMAF sensor, with stock fuel rails and lines. Sniper Commando tuned with a dyno.
I spoke with several people and they said above fuel setup will work. I am hoping that I do not peg my LMAF sensor. For me especially with stock heads I am not really going to be able to up the boost due to the bottle neck with heads and no headers 480-500 rwhp will be perfect. Going to 550 is it worth the extra coin for a complete new fuel system? For me it simply wasn't. What is your HP goal and are you using stock heads and mainfold?
It will be really interesting to me especially with new radiator and MMR 7Q oil pan - the thing holds 8 1/2 quarts of oil for cooler engine temps which is key. I have a vortech power cooler with stock heads and thinking I will be around 500 rwhp or slightly under.
__________________
03 Vert 5 speed
450 rwhp
MMR 800 Built Block
CMS 2.5 Blower Cams
12.5 PSI
Sniper Tuned
4 sale - pm me
Old 08-14-2009, 10:49 PM   #6
johnr2001gt
that should be a sweet set up when you get it done. nice job.............
__________________
03 Mach 1, full eaton swap and more 443 RWHP
johnr2001gt is offline   Reply With Quote
Old 08-14-2009, 11:14 PM   #7
Mr Graystang
Mr Graystang's Avatar
Vehicle: 2004 Ford Mustang GT 4.6
sounds like its gonna be a beast , throw some pics up and lol at the wife's reaction tell her its a Stang thang.
__________________
2004 Mustang GT Dark shadow Gray
Score !!! 2008 GSX1300R Hayabusa.
Selling Brand new Vortech V3 S/C kit. PM me.
http://mustangforums.com/forum/new-e...ml#post6615952
Mr Graystang is offline   Reply With Quote
Old 08-14-2009, 11:29 PM   #8
jvog
I am using stock heads and cams, but am throwing some headers on it. I have 60 lb injectors, and a HPX maf meter, so those aren't any issue. I was originally shooting for 525-550 rwhp but like you said, is it really worth the extra coin? According to what I read, using a BAP and even just a single focus pump aren't you supposed to upgrade your fpdm? I could go that route, but how much hp can the BAP and focus pump support?
__________________
2002 GT 5-Speed
Old 08-16-2009, 11:50 AM   #9
z06saleen
z06saleen's Avatar
Vehicle: 2002,ford,saleenmustang
2002 2v mod motor. stock heads with kennebell 2.6 liter supercharger. 14 pounds of boost. 450rwhp 500ft/lb.
z06saleen is offline   Reply With Quote
Old 08-16-2009, 11:53 AM   #10
z06saleen
z06saleen's Avatar
2002 2v mod motor stage 2 patriot heads and cams. 2.6 liter kennebell 14 pounds of boost. 520rwhp 500ft/lbs.
bap, bell, boost, build, focus, ford, fuel, hp, kenne, lmaf, modified, pump, sensor, single, update
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
