horsepower gain
I see that you changed your order to 24lb/h injectors, these will still be too large and make the engine run rich--maybe you'll only lose 10-20 HP.
The OEM tune in your '00 GT is configured for 19lb/h (orange) injectors, Ford realised these were too small and installed 21lb/h (pink) injectors in late 2001/2002 MY production. The tune (low and high injector slopes) seems to have been unaltered, making GT's with the pink injectors run a bit rich at WOT.
If you really want more power buy a tuner, you'll need it to account for any change of injector capacity anyway.
Coming from the "NITROUS EXPERT" that tells people that you have to add larger injectors to a MACH1 when you shoot a NX 150 WET shot, I find that ironic and funny as hell!
I see you have polluted this site also with your foolish INTERNET tech!
i have 24 lb/hr injectors, however i also have a cobra maf that's calibrated for it. plus i have a sniper tuner. no change in power for going from 19-24 though. the injectors just work less hard, only when the 19's are maxed will you gain power from upgrading really.
However, if you bought them you'll be ready for a F/I or N2O or ported heads later on down the road
