Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-21-2009, 10:57 PM   #11
jvog
Vehicle: 2002 Mustang GT
If hes a mechanic he should know that nearly doubling the injector size on a car will require a tune
__________________
2002 GT 5-Speed
V1 S-trim: 369 rwhp/361 rwtq
jvog is offline   Reply With Quote
Old 08-21-2009, 11:00 PM   #12
nkguillen1
Vehicle: 2001 Ford Mustang GT
Quote:
He didn't know the stick injector size, he wasn't there when i changed them.
nkguillen1 is offline   Reply With Quote
Old 08-22-2009, 12:05 AM   #13
Stevecooper
Quote:
Originally Posted by nkguillen1 View Post
2001 GT, what is the stock fuel injector size, this is killing me!!!
Stock, 19
__________________
2001 Bullitt
281CI Blue Printed Engine (Teksid, CP's, Manley Billit, Cobra Crank,) Foxlake Ported SVO heads, PI CAM's, kooks LT's, 2.3L Allen Twin Screw Blower, 63lb, SCT2800 MAF, Mcloed 8" Twin disk, Viper T-56, Griggs GR40 With Watt Link. SSR GT3's... and more.
535HP, 530TQ 12PSI .
11.77 128.5MPH (Times need some work )
5.4 Block 6L Stroker, 2V heads, Truck Intake. Sup now!
Stevecooper is offline   Reply With Quote
Old 08-22-2009, 12:07 AM   #14
Stevecooper
Correct, and technically changing injectors of the same flow rate but a different brand can / should require a tune.
__________________
2001 Bullitt
Old 08-22-2009, 12:13 AM   #15
nkguillen1
Quote:
that's my next move
Old 08-22-2009, 05:05 AM   #16
cliffyk
cliffyk's Avatar
He didn't know it was going to need a tune and honestly neither did I. Nothing got messed up thank god, but i do need the tune bad, but i need the money to do it worse, then i can sell my baby.
Neither you or your mechanic thought it would need a tune?
If you are selling the car anyway then why not put it back to stock and sell the s/c here or on eBay? The car will be easier to sell in stock condition, and you'll likely get more for the s/c by selling it separately than by leaving it on the car...
__________________
-cliff knight-
My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
cliffyk is offline   Reply With Quote
Old 08-22-2009, 09:41 AM   #17
nkguillen1
Cause what it will take to get that supercharger off is not something that i have anymore. Plus the hole that i had to tap in ym oil pan and my vaccum lines for this thing, i don't even want to go there on what the hell i'll need to do to fix it. I know it'll prolly be worth more, but hey when you need money you need money, as long as it settles my debt i'll take anything for it.
Old 08-22-2009, 10:44 AM   #18
jimmyDiablo
I have Steeda injectors on mine, not sure of what model or psi. they came on the car. Mine is tuned according to the dealer.
__________________
jimmyDiablo is offline   Reply With Quote
Old 08-22-2009, 03:19 PM   #19
stalkr
Vehicle: 1996 ford mustang
Default better 60 footer time
i have a 96 standard mustang with all bolt-ons, stage II cams, n sct tunning. i run wit 28 by 10.5 by 15 slicks, upper and lower control arms, n a detroit full locker. I have a 2.002 60 footer and i ran a best of 13.6 at 102. My friend has a 1.802 60 footer and ran 13.5 at 100 and dats without suspension upgrades and with 26 by 10 by 15 slicks. Wat is dat i need to better my 60 footer. I have good top end i just need to better my 60 footer. help me!
stalkr is offline   Reply With Quote
Old 08-22-2009, 06:20 PM   #20
vanquish
Vehicle: 2000 Mustang GT
I get what you're saying about not wanting to go through the trouble of taking it off but the things you mentioned aren't a big deal.
On the metal oil discharge tube coming out of your oil pan put a rubber cap over it with a hose clamp or zip tie.
For the vacuum line where you probably have a T-fitting due to the bypass valve just put the original straight connector back in or buy one for a couple dollars.
I agree it may be a much better idea to sell the car without the blower because you'll most likely make more money.
__________________
2000 Ford Mustang GT
Vortech V1 S Trim
JE 194329 Forged Pistons
CRS 5933F30 Forged Rods
Fel-Pro Gaskets & Bolts
Ford Racing 11" Clutch
Sniper Tuned
Pypes Violators
Mac Prochamber
B&M Shifter
Subframe Connectors
vanquish is offline   Reply With Quote
03, 2003, 36lb, bigger, change, ford, fuel, gt, injector, injectors, injectors05, mustanbg, mustang, roush, size, stock, tune
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
