Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-23-2009, 11:52 PM   #1
mustang nakotah
2006 Ford Mustang
mustang nakotah's Avatar
Vehicle: 1996 mustang gt baby!
Send a message via AIM to mustang nakotah
Default Is It OK to Drive from Florida to California?
i was thinking about sometime down the road, i wanted to drive my 96 mustang from florida to california. the problem is, is that my car has 145,000 miles on it. i really don't know anything about cars but that's a lot of miles and i don't want it to break down on the way and get stuck in another state or so. if anyone can give me some advice on how i can possibly make it without any trouble like change the oil, new tires, check the engine or something. it would be great, thanks! i don't like to fly. besides, i love driving my baby!
__________________
mustang nakotah is offline   Reply With Quote
Old 08-24-2009, 12:53 AM   #2
JC316
JC316's Avatar
Vehicle: 1996 Ford Mustang GT
Honestly, there is no guarantee that your car wont break down, but if it has been maintained, then it should be just fine. I would trust mine to go anywhere and my odometer stopped working at 156,xxx miles....
__________________
96 Laser Red Mustang GTS 248A package
5 Speed
3.27 gears
4V Mark VIII engine.
JC316 is offline   Reply With Quote
Old 08-24-2009, 01:02 AM   #3
apeterman
1996 Ford Mustang
apeterman's Avatar
Vehicle: 1996 Mustang GT
Do a full tune up on your car. Spark plugs, oil and oil filter change, tranny fluid change (and filter if auto), fuel filter change, check your tires i.e alignment, rotate and balance, check your serpentine belt, air filter (replace if over 12,000 miles or clean if washable), check your spare tire (make sure you have the lug wrench, jack and pressure is good in the tire itself), coolant flush. Do all of that and it will help you breathe easier and your car will love you, but still can't prevent something from going wrong.
apeterman is offline   Reply With Quote
Old 08-24-2009, 01:39 AM   #4
gunpig0313
gunpig0313's Avatar
Vehicle: 04 Mustang GT
Send a message via AIM to gunpig0313
If you plan on doing that go I-10 the whole way I-8 has some B!tc# a$$ hills that might cause you some problems. I drove my 87 5.0 from NY to Phoenix had no problems besides a tire blowout, and that was because I hit a re-tread, but couldn't swerve to miss. I had a 170K on the car when I made that trip.
__________________
04 GT Screaming Yellow
K&N cold air, 24# injectors, SCT tune, SLP X-Pipe, Spin Tech cat back, Hurst shifter, 3:55 gears, & a couple of Autometer gauges.
03 Aviator Ivory Pearl
Stock for now
gunpig0313 is offline   Reply With Quote
Old 08-24-2009, 06:49 AM   #5
uberstang1
Vehicle: 1997 Mustang GT
Send a message via AIM to uberstang1 Send a message via Yahoo to uberstang1
If the car runs and drives fine and hasnt given any signs of trouble id say you should be ok for the drive just do a basic tune up, the oil, tranny fluid and plugs.
__________________
97 Gt,4v swap,BBK TB, upr o/r x, slp LM1,spec clutch,spec flywheel,pro5.0,SD coil packs,imrc deletes,walbro 255lph,42# inj,procharger p600b+Intercooler,nitto 555r,420RWHP
uberstang1 is offline   Reply With Quote
Old 08-24-2009, 11:33 AM   #6
mvr
2001 Ford Mustang
mvr's Avatar
Vehicle: 01 GT
Send a message via AIM to mvr
my car had about 85k on it. i drove it from Wichita falls texas to connecticut in two days (1500 miles). a week and a half later i drove from connecticut to las vegas (2600 miles, car was packed full of all my ****) in about 4 days. car had no problems. i would suggest checking fluids, brakes, and changing oil before you start the trip. thats what i did.
car also has 3.73 gears =D
__________________
2001 Black GT 5spd
EXHAUST VIDEO
mvr is offline   Reply With Quote
Old 08-24-2009, 11:56 AM   #7
BlueBloodedPony
Forum Sn!tch
2000 Ford Mustang
BlueBloodedPony's Avatar
Vehicle: 00 Stang shooting a full clip
I would agree to the above posts, the mileage is still low IMO, a well maintained car should get you to at least 250,000. Just check fluids, tires, and see if you are due for anything to be replaced: plugs, wires, air filter, that sort of thing.
__________________
2000 Ford Mustang GT; Accufab 75mm TB&P; JLT cai; SLP lm2'S; Summit O/R H; Sniper tuned; 4:10's. SFC's, Tokico HP Series Shocks & Struts, H&R Super Sport Springs, MM Caster Camber Plates, UCA's & LCA's all are here; To be installed shortly
Quote:
Originally Posted by Rdot9 View Post
...mmmm nice and thick ftw...
BlueBloodedPony is offline   Reply With Quote
Old 08-24-2009, 01:58 PM   #8
mustang nakotah
2006 Ford Mustang
well everything sounds good then and just simple tasks like that sure does help. i appreciate the advice. thanks a lot! i'll write down the list when i plan to go in the future. now i feel less worried about it.
__________________
Old 08-24-2009, 03:43 PM   #9
liljojo4711
1999 Ford Mustang
liljojo4711's Avatar
Vehicle: 99 gt
made a trip from ky to tx (about 850 miles) and everything was great. ran the air conditioning the whole time pretty much and only stopped for gas. mine had 190xxx at the time. u take care of ur baby and she will take care of u .
__________________
5.4 4v swap soon
liljojo4711 is offline   Reply With Quote
Old 08-24-2009, 04:27 PM   #10
Capt Hair
2000 Ford Mustang
My Garage
Capt Hair's Avatar
Vehicle: 2000 mustang gt
south carolina to maine is the farthest I've been, that was with 136k on the clock. Just do a complete tune up, take some extra oil, make sure you have everything if you blow a tire. Should honestly be no problem.
__________________
2000 GT - TOTALED, first car, and my baby
97' Formula - new car, 6spd, LT4 conversion, P&P heads, Ram Clutch, B&M ripper shifter, BBK shorty headers to Y pipe, Borla catback, 3.42 geared eaton posi unit, +tune, just a little upgrade
Capt Hair is offline   Reply With Quote
ca, california, car, drive, driving, fl, florida, gear, mustang, odometer, reciprocal, registered, registration, things, vehicle
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
