got new tires, steering wheel vibration?
Old 08-24-2009, 08:57 AM
Roush2002
Roush2002's Avatar
Default got new tires, steering wheel vibration?
I got some nitto 555's installed last week. At about 45mph the steering wheel shakes. Is that an indication that I need an alignment or could the wheels not be balanced properly?
Roush2002 is offline
Old 08-24-2009, 11:19 AM
mustangchris09
mustangchris09's Avatar
what size tires are up front, if they are 245's then no, if bigger than you need alignment changes done, because at stock the alignment is thinking a smaller tire diameter, with a bigger tire up front the angles are are going to be off. I think thats right, some guy at a shop told me that.
mustangchris09 is offline
Old 08-24-2009, 11:58 AM
Roush2002
Roush2002's Avatar
i had 265 and put 265 back on.
Old 08-24-2009, 02:11 PM
mustangchris09
Its not that big of a deal, it just wears out the outer edge of the tire a little faster. Just go to a tire shop or whatever and get it aligned properly
Old 08-24-2009, 02:27 PM
Roush2002
Roush2002's Avatar
can any shop that does alignments do them on cars with caster/camber plates? I have them so thats why I am wondering.
Old 08-24-2009, 02:32 PM
devongarver
devongarver's Avatar
mine does that but its the driveshaft Im pretty sure...its not balanced properly. In you case, did the vibration start right after the new tires? Its hard to think they would be balanced improperly, but it could happened. Likely an alignment. I dont know about shops and CC plates, I dont have em myself.
devongarver is offline
Old 08-24-2009, 02:39 PM
black35th
black35th's Avatar
This might be a stupid question, but have you checked to make sure all of your lugnuts are tight?
black35th is offline
Old 08-24-2009, 02:45 PM
Roush2002
Roush2002's Avatar
no i havent. I guess I should do that. The tires that came off were worn on the outside edge and not so much on the top/inside. The guy at the tire place said its from cornering but I am wondering if an alignment is needed now.
Old 08-24-2009, 02:52 PM
Roush2002
Roush2002's Avatar
yeah it was after the new tires.
Old 08-24-2009, 03:14 PM
devongarver
I would definately get an alignment, even if it turns out the alignment doesnt solve the vibrations, its always good to get it aligned often, as it comes out easily with bumps and whatnot. If it still vibrates after alignment, then back to where you got the tires and have them re balance them.
Quick Reply: got new tires, steering wheel vibration?
