Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-02-2009, 11:07 AM   #11
devongarver
devongarver's Avatar
Vehicle: 2000 Mustang Gt 5 speed
I double checked. The regular T-56 does have a .62 6th gear. The T-45 has .67 5th gear. So, with a 3.90 rear, at 2500 rpms, the speed for each tranny is as follows:
T-45, 5th gear-approx 71mph @ 2500rpm
T-56 5th gear-approx 60 mph @ 2500 rpm
T-56 6th gear-approx 77 mph @ 2500 rpm
Viper 5th gear-approx 65 mph @ 2500 rpm
Viper 6th gear-approx 95 mph @ 2500 rpm
Hope this helps.
__________________
2000 GT 5 Spd
BBK Fenderwell, Trickflow 75mm Plenum, Summit 75mm TB, Steeda Triax, King Cobra Clutch, FRPP Flywheel, Steeda Cable Adjuster/Quadrant, SLP catted X-pipe, SLP LM1 exhaust, Sniper SF Tuning, Weld in Full Length SFCs, FRPP 4.10 Gears, Carbon Clutch Discs.
Wish list....
KB blower
Rear suspension-UCAs & LCAs in a box-need a free weekend to install
Tubular front suspension
Long tubes
*COP STICKY*
devongarver is offline   Reply With Quote
Old 09-02-2009, 12:10 PM   #12
Jazzer The Cat
Wheels/Tires Section Moderator
2002 Ford Mustang
Jazzer The Cat's Avatar
Vehicle: '02 s281 #0014
Agreed with above posts.
Need to confirm your gear ratios and have LOTS of info on that very subject in my swap thread. Be sure to understand what your getting or you may not be happy with results.
Jazzer
Jazzer The Cat is offline   Reply With Quote
Old 09-02-2009, 01:38 PM   #13
Mustang_NTriangle
Hope this helps.
U gotta love that viper tranny...
__________________
03 Vert 5 speed
450 rwhp
MMR 800 Built Block
CMS 2.5 Blower Cams
Vortech V2 SQ H.O. Aftercooled
12.5 PSI
Sniper Tuned
4 sale - pm me
38lb vortech injectors $150 shipped
21lb injectors $ 50 shipped
Aluminum Intake (replace that plastic intake) $100 shipped
(8) stock Ingition Coils $150 shipped
2004 stock short block 23,000 miles $300 B.O.
Mustang_NTriangle is offline   Reply With Quote
Old 09-02-2009, 02:47 PM   #14
teej281
teej281's Avatar
Vehicle: 2002 Mustang GT Convertible
I hate the viper tranny!!! The gear ratios are a bit odd and dont do our cars justice unless we are built to the moon. And its kinda hard to pair rear gears with the viper spec. I like the Magnum T56. It holds 700 ft lbs and it has normal gear ratios from 1-4 and then has viper like gear ratios for 5th and 6th for cruising. So i think that would be the best option.
__________________
2002 Mustang GT Conv: PYPES O/R X, Flowmaster catback, JLT cold air intake, FRPP 4.10's, Xcal 3, Strange 10 way Shocks and Struts, Eibach Pro-Kit, UPR C/C Plates, and Steeda Tri-Ax with Hurst black ball shift knob, 03/04 Cobra bumper....250rwhp, 263rwtq(with slipping clutch)
teej281 is offline   Reply With Quote
Old 09-02-2009, 03:07 PM   #15
devongarver
Quote:
Actually, with 4.10s out back, the viper spec provides a very ideal final drive ratio in each gear for a bolt on car. You can easily play and compare ratios here..
__________________
2000 GT 5 Spd
Wish list....
KB blower
Long tubes
*COP STICKY*
1996, buy, cobra, conversion, drive, install, magnum, mustang, needed, shaft, shorter, spec, speedo, t56, viper
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
