Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-01-2009, 09:44 PM   #1
Bman2000
Vehicle: 2000 mustang gt
Default probebly a dumb question about t-56
Ok so im looking at getting one very excited, but first off its coming out of a 98 cobra? i didnt think they came with one? And if they dont then that means it was a swap, but does that mean i need all the same stuff as i would getting a t-56 from a 03-04 cobra? like will the driveshaft work? comes with clutch and flywheel but i dont think that will bolt up to my GT. any help from you smarty pants would be nice.
__________________
CAI, 75mm TB, upper intake, under drive, sct tune, bassani x pipe with cats bullet style mufflers. MM subframe connectors, 2 different types of lowering springs...not sure whats in the back looks like HR with a 1.5 drop, and a lowering technologys 2.1 drop in the front. MGW shifter.
mustang dyno 225hp 275tq
Best E.T. 13.39
Best trap 105.49
Bman2000 is offline   Reply With Quote
Old 09-01-2009, 09:51 PM   #2
mustangman03
Vehicle: 03 Cobra & 03 GT
the 96-01 cobras came with a t45 trans so it must be swaped in, you will need a transmission cross member for the t56 (i think), i shorter drive shaft, and some kind of calibration for the speedo. also the flywheel will work if you have an 8 bolt crankshaft but wont if you have a 6 bolt your model year could have either one depending on if its a windsor or a romeo, windsors have 8 bolt cranks
__________________
03 GT (Daily Driver)
03 Cobra 10th Anniversary (Weekend Cruzer)
mustangman03 is offline   Reply With Quote
Old 09-01-2009, 10:32 PM   #3
Bman2000
on that subject what if its a mech. speedo? can that be changed because i have an electric
__________________
Best E.T. 13.39
Best trap 105.49
Old 09-01-2009, 10:57 PM   #4
Jazzer The Cat
Wheels/Tires Section Moderator
2002 Ford Mustang
Jazzer The Cat's Avatar
Vehicle: '02 s281 #0014
I did a T-3650~T-56 swap earlier this year and was an easy install. Lots of things to address, but went quite smoothly. You should need a new DS, but may not need the X-member as mentioned above. There were some secondary holes in mounting brackets, but cannot be certain if stock would have worked. I would recommend you pick up a Cobra one to be sure as they are only $50.00 or so.
What are your reasons for the T-56? I went with one due to failing T-3650 bearings and the mega-gap between 4th~5th gears. There are several different models so be sure to address the gear ratios as some are very similar to yours and some differ quite a bit.
Jazzer
Jazzer The Cat is online now   Reply With Quote
Old 09-01-2009, 11:12 PM   #5
Bman2000
to be honest, i dont need one, i just like six speeds alot...had one in my maxima, always wanted one, need a new tranny figured nows a good time for what i want. There are advantages tho. Such as a 6th gear to drop the rpm back down to normal level once ive put 3.90s in it, and of course close ratio 1-4 will help alot with keeping me ontop of the torque when flying down the drag strip or around corners. there isnt really anything i can do if its mechanical speedo tho huh? at that point its probebly not worth the money?
__________________
Best E.T. 13.39
Best trap 105.49
Old 09-01-2009, 11:38 PM   #6
teej281
teej281's Avatar
Vehicle: 2002 Mustang GT Convertible
Well i dont know of any mustangs in the 90's with this tranny in it so he must have done something to it to convert it to mechanical speedo. Now you just have to figure out what he did and reverse it. Plus a lot of the sites on the web that offer tranny swaps and stuff say they can be used in electronic or mechanical speedo cars. So you just gotta find out what to do to make the swap. Call around and find out. Cus im pretty sure that the 96-98 gt's use the same tranny as the 99-01's and the 99-01's have electronic speedo's and the 96-98s are mechanical. So there has to be something to be able to use it with electronic speedo cars.
__________________
2002 Mustang GT Conv: PYPES O/R X, Flowmaster catback, JLT cold air intake, FRPP 4.10's, Xcal 3, Strange 10 way Shocks and Struts, Eibach Pro-Kit, UPR C/C Plates, and Steeda Tri-Ax with Hurst black ball shift knob, 03/04 Cobra bumper....250rwhp, 263rwtq(with slipping clutch)
teej281 is offline   Reply With Quote
Old 09-02-2009, 01:17 AM   #7
livefast1
livefast1's Avatar
Quote:
order a speedometer for an 03 cobra? came with a a t56 and an electronic speedo so i don't see why that won't work.
__________________
looking for a notch back or a 4 eyes (preferably a notchback 4 eyes).
livefast1 is offline   Reply With Quote
Old 09-02-2009, 07:34 AM   #8
teej281
teej281's Avatar
But this transmission is coming out of a 98 cobra...how would buying the 03 cobra speedo solve his problem of the transmission having mechanical speedo stuff to making it electronic???
__________________
Old 09-02-2009, 08:07 AM   #9
devongarver
devongarver's Avatar
Vehicle: 2000 Mustang Gt 5 speed
Quote:
This may not be the case unless you get a viper spec t-56, the 6th gear in a normal t-56 is like .62 i think...and our t-45 is like .67, where as the viper is .50, just something you might want to check first.
__________________
2000 GT 5 Spd
BBK Fenderwell, Trickflow 75mm Plenum, Summit 75mm TB, Steeda Triax, King Cobra Clutch, FRPP Flywheel, Steeda Cable Adjuster/Quadrant, SLP catted X-pipe, SLP LM1 exhaust, Sniper SF Tuning, Weld in Full Length SFCs, FRPP 4.10 Gears, Carbon Clutch Discs.
Wish list....
KB blower
Rear suspension-UCAs & LCAs in a box-need a free weekend to install
Tubular front suspension
Long tubes
*COP STICKY*
devongarver is offline   Reply With Quote
Old 09-02-2009, 10:40 AM   #10
teej281
teej281's Avatar
Yea, the regular t56 has the same 6th gear as our transmissions have 5th. So it wont drop the rpms. Now the magnum t56 has normal 1-4th and 5th and 6th are higher than normal...i think. That would be the only 6 speed that i would put in my car.
__________________
1996, buy, cobra, conversion, drive, install, magnum, mustang, needed, shaft, shorter, spec, speedo, t56, viper
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
