Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-08-2009, 02:47 PM   #1
loweredfourpointsix
loweredfourpointsix's Avatar
Vehicle: 2002 ford mustang gt
Send a message via AIM to loweredfourpointsix
Default Help with DTC Code
dtc 5284 Oil pressure switch failure: ok so my car threw this code a few months back but everybody says its no big deal. only problem is i have to pass smog and i need to have the CEL off in order to pass. ive tried disconnecting the battery as well as clearing the code with a predator tuner but it comes back on. any suggestions?
__________________
Barely ran a 13.8@101mph with all these upgrades - K&N FIPK (filter and heatshield), 70mm PP TB, C&L plenum, UPR catted xpipe, H&R sport springs, Mickey Thompson E.t Streets.
loweredfourpointsix is offline   Reply With Quote
Old 09-08-2009, 04:07 PM   #2
socalwrench
socalwrench's Avatar
Vehicle: 2008 Mustang V8
Replace the oil switch? It's there to control something. The code will keep coming back no matter how many times you clear it.
__________________
Greg - Owner/Operator: GRH Performance
socalwrench is offline   Reply With Quote
Old 09-08-2009, 04:07 PM   #3
cliffyk
cliffyk's Avatar
If the SES light is on, it is some code other than 5284, which you must have read using the instrument cluster diagnostics. Code 5284 is a "normal" bug in the cluster diag function--read more here.
The instrument cluster diagnostic function does not report powertrain DTCs (the ones that make the SES light come on), just a few body and chassis codes that have nothing to do with engine operation. You need to buy a code scanner (Harbour Freight has a competent one that is often on sale for $30), or go by your FLAPS and have them read the code(s) that are triggering the SES, via the OBD2 port.
__________________
-cliff knight-
My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
cliffyk is offline   Reply With Quote
Old 09-08-2009, 04:40 PM   #4
loweredfourpointsix
ok so your saying i have to get it scanned by a mechanic or buy a scanner? im not sure if i understood what you were trying to say. are you saying that the code it throws is actually a different code? sorry if that doesnt make sense im just a lil confused from partying to hard this weekend haha
__________________
Old 09-08-2009, 04:53 PM   #5
cliffyk
cliffyk's Avatar
Quote:
The codes displayed by the instrument cluster diagnostic mode have nothing to do with the SES (CEL, MIL, etc.) light being on. They are body and chassis codes, and the 5284 code specifically is shown because of an error in the instrument cluster diagnostic program--there is nothing wrong with the oil pressure switch...
The SES (CEL, MIL. whatever we want to call it) is on because of some engine/power train problem that cannot re read through the instrument cluster. You need to buy a code scanner or go by almost any Favourite Local Auto Parts Store (FLAPS) where they will read the code(s) for you, usually for free
Write down the code or codes, they will be "P" followed by 4 numbers--don't worry about what they tell you is wrong as they will just provide the generic description and are often incorrect as to what the real problem is--just get the codes.
When you get the codes look them up here to fins out what is causing them, possible fixes, and diagnostic tips.
__________________
-cliff knight-
My Mustang
Old 09-08-2009, 09:51 PM   #6
loweredfourpointsix
thanks cliffy i appreciate it
__________________
07, 2000, 46, code, codes, diagnostic, dtc, freight, harbor, mode, mustang, obd, s197, scanner, trouble
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
