Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-11-2009, 10:53 AM   #1
MTBer
Vehicle: 2004 Mach 1
Default TR3650 rebuild kit/upgrade
My tranny has a problem where if I disengage the clutch and shift from neutral to reverse, it grinds, but if I shift into a forward gear first, then shift to reverse, it usually (but not always) goes right in.
Over the winter, I'd like to have the tranny torn apart and rebuilt. While it's out of the car, I figure now would be the best time to do whatever I can to strengthen it and fix whatever inherent flaws are present.
Are there any kits made specifically for this purpose? I wouldn't mind a T56 or a TKO600, but I don't want to spend that much, and even when I'm done with the power mods on my car, I don't plan on making more than 330rwhp so other transmissions would probably be overkill anyways.
MTBer is offline   Reply With Quote
Old 09-11-2009, 11:07 AM   #2
Jazzer The Cat
Wheels/Tires Section Moderator
2002 Ford Mustang
Jazzer The Cat's Avatar
Vehicle: '02 s281 #0014
All my manual transmissions have had this same issue and was told it was due to lack of synchros in reverse. I think my new T-56 does the same thing, but am so used to going 1st prior to R, I can't recall for sure.
If this is the ONLY issue you have with it, leave it alone.
Jazzer
Jazzer The Cat is offline   Reply With Quote
Old 09-11-2009, 11:16 AM   #3
MTBer
I would leave it alone, but I can't always get it into reverse even if I first go to a forward gear. It just locks it out. My other Mach 1 never had this problem.
Old 09-11-2009, 02:05 PM   #4
loweredfourpointsix
loweredfourpointsix's Avatar
Vehicle: 2002 ford mustang gt
Send a message via AIM to loweredfourpointsix
my 89 5liter would always grind into reverse if you didnt go into a forward gear first. my 2002 locks you out of reverse unless you go into a forward gear also. if my gf is driving sometimes she has to turn off the car to put it in reverse then start it bcuz she cant get it into reverse.
__________________
Barely ran a 13.8@101mph with all these upgrades - K&N FIPK (filter and heatshield), 70mm PP TB, C&L plenum, UPR catted xpipe, H&R sport springs, Mickey Thompson E.t Streets.
loweredfourpointsix is offline   Reply With Quote
Old 09-11-2009, 06:11 PM   #5
Jazzer The Cat
2002 Ford Mustang
I sometimes have a somewhat similar issue where I have to apply just a bit of forward "load" on trans to get into anything other than 1st~2nd. Happens occasionally and figure it is just a synchro issue and have not worried about it so far, just an odd issue.
Jazzer
Old 09-13-2009, 02:35 AM   #6
MTBer
Well, after playing around with it for awhile, I found that if I'm in neutral, press in the clutch, and wait a couple seconds, I can shift into reverse without grinding. However, if I try shifting to reverse immediately after pressing the clutch pedal, I get a grind.
Old 09-13-2009, 09:58 AM   #7
Jazzer The Cat
2002 Ford Mustang
When the motor is running and the clutch is out, the trans main shaft is rotating. If you dis-engage the clutch the shaft will stop spinning in that couple seconds and allow you to find reverse w/o grinding.
This is due to the lack of synchro's, as I understand.... normal.
Jazzer
06, 3650, buy, cost, gt, kit, kits, mustang, rebuild, rebuilt, sale, synchro, tr, tr3650, transmisson, upgrade
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
