Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-20-2009, 12:54 PM   #1
rman101
2002 Ford Mustang
Vehicle: 02 GT Vert
Default Help my 60ft and MPH!
second time at the track last night.
last time i ran 2.3 and a 2.7 60 this time a 2.3 again.. however i was running my new tires and was spinning considerably. off the line. now as for the 60ft i know LCA, drag springs, and DR's but i just got new tires so i might look for some used DR's or slicks and put them on 16inch pony rims (pretty light weight) only thing with that is do i put them on for the 45 minutes drive to the track?
Second my MPH ... last time i thought the track was messed up. I trapped a 74 and a 69 this time a 72.... are those normal ? i was told i should trap 15 more! but i thought 99 mph trap speeds where for 1/4 mile norms not 1/8th... whats up with this??
rman101 is offline   Reply With Quote
Old 09-20-2009, 12:58 PM   #2
SVTeeshirt
Vehicle: 1996 Mustang Cobra
your MPHs are so high because you're spinning so much off the line. What are you launching at? Auto or manual and what size tires.
__________________
Fastest Closet on MustangForums.
I bought a goldfish, named it after my ex-girlfriend, and let it die. It's really the little things in life.
SVTeeshirt is offline   Reply With Quote
Old 09-20-2009, 02:04 PM   #3
rman101
2002 Ford Mustang
Vehicle: 02 GT Vert
Auto GT Convertible launching at around 2.3k -2.5k rpms... whatever it holds to i know once i feel it start slipping i let off the gas lol. but was so into it i didnt look.
255 nexan N3000's not the best for drag but good for DD.
and wait my 69 72 and 74 times are high? i was told they where low and i should be around the 90+ but like i said i thought people where trapping 99 in the 1/4 (i raced on the 1/8th)
Old 09-20-2009, 02:18 PM   #4
fisher2985
fisher2985's Avatar
Vehicle: 01 gt
i put down a 1.99 60ft, with just ford racing b springs, and yokahama 275/40 s drives. but i dont load the converter, just when the light turns green hold it to the floor.
my best time s far (only been to the track once) is an 8.70 at 80 miles per hour.
__________________
01 gt, 75mm prof prod throttle body and upper plenum, bbk cold air intake, march underdrive pulleys with sfi approved balancer, pypes long tubes and off road h-pipe, magnaflow mufflers, 4.10 ford racing gears, ford racing carbon fiber limited slip kit, granitelli tuner, ford racing b springs, drifz gtr 17x9,www.twistedstallions.com FOR SALE$9000 PM ME
fisher2985 is offline   Reply With Quote
Old 09-20-2009, 02:32 PM   #5
72MachOne99GT
1999 Ford Mustang
72MachOne99GT's Avatar
Vehicle: 1999 Ford Mustang GT
Send a message via AIM to 72MachOne99GT Send a message via Yahoo to 72MachOne99GT
You ought to be trapping closer to 80 in the 1/8th, and near 100 in the full quarter mile. I just think there was a mix up above.
The Trap speed isn't nearly as important as the ET though as I'm sure you know. As of now, I'd say that your 60' is what's killing you.
__________________
'99 GT-5sp.
4.10's, O/R H, catback, MT's
13.6@100 1.8 60'
72MachOne99GT is offline   Reply With Quote
Old 09-20-2009, 04:58 PM   #6
SVTeeshirt
yeah o.p im unfamillar with the 1/8th, only the 1/4 around here i thought YOU thought the times were fast, get some new tires, wider at that.(you could go 275s)
__________________
Old 09-22-2009, 10:26 AM   #7
ZW99GT
Moderator
ZW99GT's Avatar
Vehicle: 1999 GT
74-75 should be just about close. Whoever said you needed to be in the 90's is mistaken. 90's is 400hp territory as far as the 1/8 is concerned.
stock gear + stock converter Auto + 255 nexans = recipe for disaster as far as launching is concerned. You have alot of work to do in that department. Gears and sticky tires at the very least. A 255/16 BFG d/r would work well on an old set of wheels, and they should last for quite a while on the street as well. Pair that with 3.73's and you should be at least in the sub 2.0 range.
__________________
Stock 351W
ZW99GT is offline   Reply With Quote
1999, 25, 410, 60, 60ft, cobra, dragster, ft, gears, good, inconsestant, mustang, seconds, time, times, whats
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
