Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-26-2009, 02:05 PM   #21
avlon06
avlon06's Avatar
Vehicle: 2000 Mustang GT
Quote:
Originally Posted by DS002 View Post
What do you need a stroker for? Just grab an f150 block and get to work. But even then itd probably go over 5k, but probably not by much. Having to do a high comp fully forged rotating assembly is going to be big bucks whether its a stroker or not unfortunatly.
whats the point for the f150 block?
__________________
Exhaust clip
avlon06 is offline   Reply With Quote
Old 09-26-2009, 02:10 PM   #22
99BlackPonyGT
aka Negative Nancy
Vehicle: 1999 Mustang GT
Send a message via AIM to 99BlackPonyGT
Quote:
more cubes
99BlackPonyGT is offline   Reply With Quote
Old 09-26-2009, 02:12 PM   #23
boduke0220
2003 Ford Mustang
Vehicle: 2003 Mustang GT
Send a message via AIM to boduke0220
think about it though, maybe im just retarded but if the foxlake ported TF's flow 263cfm's. and what do 4v's flow? right around there isnt it? and they are capable of 370+, i dont see why it would be so hard. only bad part would be reving your motor to the moon
__________________
CARS FOR SALE!!! $8500!
boduke0220 is online now   Reply With Quote
Old 09-26-2009, 02:18 PM   #24
Xemeth
Vehicle: 2002 GT
Send a message via AIM to Xemeth
Quote:
Do you mean capable of 370+ CFM? Or RWHP? Cause you're never getting any modular head to flow 370 CFM.
FYI, ported 4v heads can flow 300+ CFM.
__________________
2002 GT, H/C/I 4v.
Xemeth is offline   Reply With Quote
Old 09-26-2009, 04:13 PM   #25
DS002
High revving V8's are like sex to my ear drums. Id love to build a 5.4L 2V or 4V and make it rev to 8k or so, thatd probably make for one of the sexiest exhaust tones ever.
__________________
DS002 is offline   Reply With Quote
Old 09-26-2009, 04:46 PM   #26
GTRACER88
GTRACER88's Avatar
It would cost you over 5k for a 5.4L High compression with the TFS heads. As stated TFS heads, cams, and ported heads will cost you 3k alone. Add the HPS intake $800 that = $3800. Plus buying a 5.4L ford f150 block $100= $3900. Finally buying new rods pistons bearings crank and having them all balanced will cost you near $1200 dollars. While your at it bore the block .020+ over $150. You are already at $5250 before tax and shipping. Assuming your going to do all the work.
__________________
Mods: Too much and not enough
The only thing worse than socialism is ignorance.
GTRACER88 is offline   Reply With Quote
Old 09-26-2009, 04:59 PM   #27
DS002
Quote:
Considering I just guessed 5k in a split second Id say I did a pretty good job with my estimate, itd probably come out closer to 6-6.5k after all is said and done though.
__________________
Old 09-26-2009, 05:26 PM   #28
nickmckinney
nickmckinney's Avatar
Vehicle: 96 Bipolar GT
Hard part is getting the TFS head to keep that flow with an intake bolted to it. My best guess on the plastic intake is about a 210CFM intake limit give or take.
__________________
96 Bipolar GT
nickmckinney is offline   Reply With Quote
Old 09-26-2009, 08:47 PM   #29
teej281
teej281's Avatar
Vehicle: 2002 Mustang GT Convertible
any tests on any aftermarket intake manifolds??? Or ported plastic manifolds??? Just a thought since you arent putting pressure into the manifold...just vacuum.
__________________
2002 Mustang GT Conv: PYPES O/R X, Flowmaster catback, JLT cold air intake, FRPP 4.10's, Xcal 3, Strange 10 way Shocks and Struts, Eibach Pro-Kit, UPR C/C Plates, and Steeda Tri-Ax with Hurst black ball shift knob, 03/04 Cobra bumper....250rwhp, 263rwtq(with slipping clutch)
teej281 is offline   Reply With Quote
Old 09-26-2009, 09:00 PM   #30
GTRACER88
GTRACER88's Avatar
I forgot to add new injectors, fuel pump, dyno tune so it comes out above 6k.
__________________
2v, 46, 98, cams, cms, density, fastest, gt, heads, mach, mustang, mustangs, n/a, na, power, speed
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
