Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-26-2009, 05:37 PM   #11
mrtstang
Vehicle: 2004, Ford, Mustang Gt
Quote:
Originally Posted by 02stangdude View Post
how much power should i gain? i hear ppl saying a full bolt on gt with these cams should make around 300rwhp but im only at 256..r they really gona give me 44 more hp? might b cuz i have different plugs in my car tho...when i got my nitrous put on i put colder plugs in and got it retuned. befor the plugs it made 264
The plugs themselves shouldn't make a difference. When i did my nitrous, my n/a numbers were no different with the colder plugs.
I don't believe you'll gain 44 hp from those cams alone. At least not peak to peak numbers. I've seen the literature, and some may dissagree, but i don't buy it!
__________________
2004 DSG Mustang Gt, BBK long tubes, BBK catted h pipe, SSS Terminator Catback, K&N cai, Steeda UDP's, Accufab 75mm tb/plenum, FRPP aluminum ds, Motive 3.90 gear, Alternative Auto custom tune, Steeda Tri-Ax, DD black bullitts w/315's Nitto 555R's, & 100 shot N20. 269/305 na, 373/528 N20
mrtstang is offline   Reply With Quote
Old 09-26-2009, 07:33 PM   #12
H0SS302
2001 Ford Mustang
Vehicle: '01 GT Vert;
Send a message via AIM to H0SS302
Pll go from 260 with bolt ons to 300 all the time with hitech stge 2s... its very common. Most stage 2s will give you those results.
__________________
Corner Carving > All
H0SS302 is offline   Reply With Quote
Old 09-26-2009, 10:21 PM   #13
mrtstang
Quote:
I'm not saying it can't be done, but i wonder sometimes how they compare the before and after numbers. Sure, maybe they gain 40 hp at 6k over stock, but what are the peak to peak comparisons, and where do they occur? Is there any extra tuning (which would account for some of the numbers) that has been done?
40+ hp from just cams (no retuning, coparing #'s at 6k, etc.) on a naturally aspirated, stock headed, and stock intake setup just doesn't seem right to me.
__________________
Old 09-26-2009, 11:00 PM   #14
boduke0220
2003 Ford Mustang
Vehicle: 2003 Mustang GT
Send a message via AIM to boduke0220
well obviously you wont gain as much without the dyno tune, but the gains will still be there.
__________________
CARS FOR SALE!!! $8500!
boduke0220 is offline   Reply With Quote
Old 09-27-2009, 12:34 AM   #15
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
Vehicle: Stock 96 GT
Send a message via AIM to sxynerd Send a message via Yahoo to sxynerd
Apples and oranges but my 2.5 blower cams gave me an additional 52rwhp at the same 10lbs of boost. But no telling of the benefit with 16lbs and it pulls like a freight train all the way past 6500rpm. The performance of a good after market set of cams far outweighs the dyno numbers.
sxynerd is online now   Reply With Quote
Old 09-27-2009, 01:51 AM   #16
02stangdude
02stangdude's Avatar
Vehicle: 2002 mustang gt
sxynerd...why would u go woth the cms or w.e they r called cams over the hi techs? and i would deffinatly get a new tune after the cams.
__________________
full bolt ons plus 100 shot 256-N/A 360-100 shot
13.35 @101 1.77 60ft n/a
12.70 @ 110 1.8 60ft 100 shot.
02stangdude is offline   Reply With Quote
Old 09-27-2009, 03:25 AM   #17
H0SS302
2001 Ford Mustang
Ok wow..
for 1, you NEED a tune with stage 2 cams for your car to even run right, 2, The bolded part is just to me.
Stage 2 cams are going to pull to well above 6k.. peak to peak comparisons with a stock cam vs a stage 2 are going to yield you 40+.. like i mentioned earlier.. A peak is just that, the maximum height of the parabola.. You WILL gain 40+ peak hp with any off the shelf decent stage 2 grind with full bolt ons.. A tune is part of it to make your car run right.
__________________
Old 09-27-2009, 08:58 AM   #18
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
I've seen his cams make the numbers time and time again. The fastest 2v cars are running his cams. CMS/VT's cams have always been the cams to get for as long as I can remember. I've seen 50rw from CMS stage 2 cams with a fully built 10.6:1 car and although, it's not the norm, these cars function best with all the mods combine. A stock car is going to pick up around 30rw with his stage 2 cams while a fully built car is going to react better with them. 340-360rw is what you'll end up with on a fully built engine and all the mods through a manual trans.
Like I said before Hitechs don't make the peak Hp numbers and give up power for the longer curve which is good and bad. Besides, HiTech is a GM based company and they only just started doing ford parts a few years ago. Call me biased but I wont go to GM company for anything, lol.
Old 09-27-2009, 09:04 AM   #19
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
Ok wow..
I wont confirm this because I don't want people to get upset if their car doesn't make that magic number BUT it is true, there have been a lot of people to get those numbers. That is also something I didn't think of OP, that with a stage 2 cam, (Unless you're built) you may not be able to take full advantage of the RPM range and not net those big numbers.
Comps big thumper cams aren't even that bad of a cam BUT you'll need to be notched and degreed to run those. The big thing about Hitech and CMS is you wont need to notch your pistons.
Old 09-27-2009, 09:14 AM   #20
boduke0220
2003 Ford Mustang
how high can the stock bottom end rev to?
__________________
2004, 46, cam, cams, gt, high, hitech, hitechs, hp, ii, motorsports, mustang, stage, tech, tune
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
