I love that video, but that guys times are more a testament to his drivetrain and suspension setup than it is the cams. Dont think youre going to be slapping in a set of hi-techs and be running low 12's or trapping 112.
for 1, you NEED a tune with stage 2 cams for your car to even run right, 2, The bolded part is just to me.
Stage 2 cams are going to pull to well above 6k.. peak to peak comparisons with a stock cam vs a stage 2 are going to yield you 40+.. like i mentioned earlier.. A peak is just that, the maximum height of the parabola.. You WILL gain 40+ peak hp with any off the shelf decent stage 2 grind with full bolt ons.. A tune is part of it to make your car run right.
I've personally seen probably a half dozen pi head mustangs dyno with stage 2 cams. The best i saw (with stock heads and intake) was with CMS stage 2's. It gained 32 hp at the peak. Others i've seen seem to get around 25-30 hp max. I've seen blower cars pull a little higher.
Again i don't doubt 40+ on a naturally aspirated, stock head and intake stang, but i've never personally seen it.
__________________
2004 DSG Mustang Gt, BBK long tubes, BBK catted h pipe, SSS Terminator Catback, K&N cai, Steeda UDP's, Accufab 75mm tb/plenum, FRPP aluminum ds, Motive 3.90 gear, Alternative Auto custom tune, Steeda Tri-Ax, DD black bullitts w/315's Nitto 555R's, & 100 shot N20. 269/305 na, 373/528 N20
Hell even JayC gained 40+ with his CMS cams IIRC. Everyone that I know with bolt ons and stage 2 cams hit between 295-305...
EDIT: just scrolled up and say Jays post..
I think you have been brainwashed by the bullet cam grinds lol..
+1...it's all his mods combined that net him those times...suspension, gears, slicks, obviously cams/bolt ons and of course, the driver mod...
Who buys 17" Saleens? It's like having a mentally challenged girlfriend. Everyone's proud of you for having a GF and that you're not gay but they still feel bad for you.
Trap speed doesnt lie.. it tells you how fast a car really is.
so cms cams r deffinatly better then the hi tech? i mean i have a 100 shot on the car so id like to hage a strong car n/a but also get benifits from the nitrous/cams. im trapin 105 now...with cams do u think 108 is possible like jayc is doin? i understanbd his times donnt only come from the power he is makin...im sure he has a pretty sick suspension set up as well
__________________
full bolt ons plus 100 shot 256-N/A 360-100 shot
13.35 @101 1.77 60ft n/a
12.70 @ 110 1.8 60ft 100 shot.
