Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-27-2009, 08:20 PM   #1
WannaBeGearHead
Vehicle: '00 Mustang GT
Default Brake caliper, pads and rotors help
Well I looked over my car and noticed that my rotors are worn/warped and the rear driver's side caliper is so bad that (I can't describe the exact problem) it wears my pads different and all my pads are close to worn out.
Well I did some research and found the pads and rotors I want...
I am getting the Hawks HPS brake pads and the Powerslot front and rear rotors. Those I have read are the popular choices among many members.
My problem is I am having a hard time find new calipers for my front and rear. Can someone suggest a good brand of caliper that I can get?
WannaBeGearHead is online now   Reply With Quote
Old 09-27-2009, 08:29 PM   #2
99BlackPonyGT
aka Negative Nancy
Vehicle: 1999 Mustang GT
Send a message via AIM to 99BlackPonyGT
http://www.americanmuscle.com/cobra-full-brake-kit.html
99BlackPonyGT is offline   Reply With Quote
Old 09-27-2009, 08:53 PM   #3
vanquish
Vehicle: 2000 Mustang GT
If you want stock calipers to work with the pads and rotors you mentioned just go to carquest or napa with the old calipers and get new ones they aren't too much money.
__________________
2000 Ford Mustang GT
Vortech V1 S Trim
JE 194329 Forged Pistons
CRS 5933F30 Forged Rods
Fel-Pro Gaskets & Bolts
Ford Racing 11" Clutch
Sniper Tuned
Pypes Violators
Mac Prochamber
B&M Shifter
Subframe Connectors
vanquish is offline   Reply With Quote
Old 09-27-2009, 10:14 PM   #4
DarkRacerx
2004 Ford Mustang
Vehicle: 2004 Ford Mustang Gt
Go to this thread: Best Brakes and Rotors to buy. Great advice in it
http://mustangforums.com/forum/4-6l-...rs-to-buy.html
DarkRacerx is offline   Reply With Quote
Old 09-27-2009, 10:32 PM   #5
GTRACER88
GTRACER88's Avatar
www.buyfordracing.com
Check out the cobra calipers.
__________________
Mods: Too much and not enough
The only thing worse than socialism is ignorance.
GTRACER88 is offline   Reply With Quote
Old 09-27-2009, 10:42 PM   #6
DarkRacerx
2004 Ford Mustang
99BlackPonyGT:
Question about your post? Would that kit be better than getting powerslot rotors? Because you get not only the rotors but also:
2x Charcoal Rear Cobra Specification Calipers
Factory OEM Rear Pads
Blank OEM 11.65" Rear Rotors
Caliper Mounting Brackets
Moan Braces
Dust Shields
Dust Shield Bolts
..... because I had powerslot & hawk brakes picked out & ready to go but know Im wondering if I need also new capilers because im doing the rotors and pads. Thoughts>>>
Old 09-27-2009, 11:38 PM   #7
WannaBeGearHead
Quote:
Originally Posted by 99BlackPonyGT View Post
I really like that kit. The only problem with that is it says you have to have 17" rims. Mine are only 16".
Quote:
I will look into that if the Cobra kit on AM doesn't work. Is there really that big a difference between the stock calipers and an aftermarket?
Old 09-28-2009, 12:40 AM   #8
hpwrestler220
hpwrestler220's Avatar
Vehicle: 2001
save yourselves all money...
buy from buyfordracing.com
AM is usually the cheapest, but not in this case
__________________
Things to do:
1) Fix exhaust leak
2) Remove isolators
3) Get rear decklid shaved and painted DONE
4) Get fog lights sprayed with black/clear mix
5) Get lower valence re-sprayed
So far, i'm 1/5....
hpwrestler220 is offline   Reply With Quote
Old 09-28-2009, 08:00 AM   #9
vanquish
I thought you were doing stock size rotor and pad replacement. I didn't know you were planning on doing a whole brake kit swap. If you are going with larger cobra pads and rotors you're going to need the calipers from that too.
__________________
Vortech V1 S Trim
Sniper Tuned
Pypes Violators
Mac Prochamber
B&M Shifter
Subframe Connectors
Old 09-28-2009, 10:00 AM   #10
WannaBeGearHead
Do I really need to buy the Hawks brake pads or can I buy some from Advanced Auto Parts? (Hawks or cheaper from AAP)
I still like the Powerslots rotors a lot and am set on those. And if I buy the Cobra calipers, will I need to buy a kit to make them work on the Powerslot rotors?
2000, aftermarket, brake, caliper, calipers, carquest, choices, cobra, differences, gt, mustang, napa, pad, pads, rotor, worn
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
