Hi All! I am new here. My 2002 GT engine light came on PO306. 1st thought it was fuel injector, then coil. None of the above. Did a compression test on all cylinders. # 6 came up bad with 95. The rest were right at 150 or better. Did the oil test on #6 and compression jumped to 125.
So, it looks like it's a ring/piston problem. I was hoping with the low compression it might be a exhaust valve. Someone said it could be a head gasket as well. Is that true???
Anyway, do you have to take out the engine to install the ring on that cylinder if that's what it is? Any way possible to raise the piston without taking the engine out?
Car only has 67K miles on it. Am I looking at replacing the whole engine with a used one because of one stupid piston? What the labor charge for yanking one out, and replacing it with a decent used engine? I know the used engine comes with everything basically assembled, like manifold valve convers etc. So it should be somewhat cheaper to assemble than a rebuilt long block.
Sorry for all the questions, but I really not sure which way to turn here!!
Thanks
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
To do it with the engine in the car you will obviously need to pull the driver's side head (the brake booster needs to come out IIRC), then use an engine support beam (click here) to hold the engine up while you drop/remove the front crossmember so that you can get the oil pan off. You can then take the rod and piston out.
__________________
-cliff knight- My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
In my opinion if it was a blown gasket you would have water in the cylinder and it would be getting hot.
I have never seen anyone put just one piston in with the engine still in the car but the way cliffyk is explains it, makes it sound like it can be done.
__________________
Auto 99GT (35th ann),BBk Cia 3:73's,BBk76mm tb BBK Plenum,MAC LT's,MAC Prochamber,Port and Polished the stock heads,Flowmasters,Steeda UDP,160 therm,XCAL 3,Tuned,Tranny rebui
I was not advocating it, but it could be done...
__________________
If youre going to do just one piston, i think its a waste. Just pull them all and do some upgrading in there if you can. Or maybe not upgrade but just replace while youre in there so you know what youre working with.
__________________
2002 Mustang GT Conv: PYPES O/R X, Flowmaster catback, JLT cold air intake, FRPP 4.10's, Xcal 3, Strange 10 way Shocks and Struts, Eibach Pro-Kit, UPR C/C Plates, and Steeda Tri-Ax with Hurst black ball shift knob, 03/04 Cobra bumper....250rwhp, 263rwtq(with slipping clutch)
i know u said oil brought the compression up, but i would seriously look at having a bad valve. ive seen several 4.6's in trucks and expeditions with a single cylinder misfire that turned out to be burnt valve problems. worth checking into before u call i a bad engine.
__________________
01 gt, 75mm prof prod throttle body and upper plenum, bbk cold air intake, march underdrive pulleys with sfi approved balancer, pypes long tubes and off road h-pipe, magnaflow mufflers, 4.10 ford racing gears, ford racing carbon fiber limited slip kit, granitelli tuner, ford racing b springs, drifz gtr 17x9,www.twistedstallions.com FOR SALE$9000 PM ME
bad valve isnt gonna care if you put oil down there
