Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-29-2009, 12:03 AM   #11
sweger
2004 Ford Mustang
My Garage
sweger's Avatar
Vehicle: 2004 GT
Send a message via AIM to sweger Send a message via Yahoo to sweger
wow thatsa a sad video...
sweger is offline   Reply With Quote
Old 09-29-2009, 12:06 AM   #12
01GT4.6
Moderator
2001 Ford Mustang
01GT4.6's Avatar
Vehicle: 2001 Mustang GT
lol, yeah she's seen much better days at the track.
01GT4.6 is offline   Reply With Quote
Old 09-29-2009, 12:21 AM   #13
ZW99GT
Moderator
ZW99GT's Avatar
Vehicle: 1999 GT
It's not all that tough to pull the driver's side wheel. Its pretty tough to get them both up. It doesn't make sense, but power and 60fts and etc...... don't directly influence if or how high you pull the wheel(s).
I cut a 1.43 60ft and barely (maybe just a tad of daylight) pulled both tires. I made a TON of 1.5's and alot of those weren't pulling either wheel. It was just straight hooking and going, which is really what you want.
My buddy with a Procharged Trans Am pulls low 1.5 60fts and he jerks both wheels up HIGH! Like 2ft in a couple instances. My car launches harder and goes side by side with him down the track and run 7.0's. But mine left smooth and his popped up. I guess it's all in your setup.
__________________
Stock 351W
ZW99GT is offline   Reply With Quote
Old 09-29-2009, 12:27 PM   #14
cliffyk
cliffyk's Avatar
350 to 400 lbft available at the crank, in 1st with 4.10s, well-connected to the pavement would do it handily.
Keep in mind that at the moment of launch available torque includes not only what the engine is producing, but also the release of the kinetic energy stored in the engine's rotating mass and the flywheel as those assemblies are rapidly decelerated.
__________________
-cliff knight-
My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
cliffyk is offline   Reply With Quote
Old 09-29-2009, 01:36 PM   #15
03BottleFedGT
03BottleFedGT's Avatar
Vehicle: 03 GT, 68 Coupe,
for good times and et's you really dont want the wheels up. when i was younger and built my first race car the coolest thing was to stand it on the bumper. till the day tim lynch ragged the hell out of me for it and explained why it was bad. now depending on the track and how i set up the suspension on average i pull up both about a half inch with 1200hp twin turbo fox(1.2 1.3 60ft). but if ya really want to do it 4.10 gear 50/50 drag shocks in the back and slicks on a stock car and you got the tires up
__________________
A.S.E. Master Tech, Ford Factory Trained Tech, and SVT Trained Tech
D.S.S. 5.1 stroker built by ProLine Race Engines, 200 shot, TCI 4r70w trans, 3200 stall, trick flo heads, stage 2 cms cams, Long tubes, o/r h-pipe, flows, eibach pro-kit, 4.10 gear, 03 cobra deep dish in black, tuned by Tim Barth at Modular Power House
03BottleFedGT is offline   Reply With Quote
Old 09-29-2009, 01:43 PM   #16
99GTvert
6th Gear Member's Member
99GTvert's Avatar
Vehicle: 1
Quote:
Originally Posted by dimebag View Post
I'm at stock power on motor... Only thing that helps w power is an or x pipe, and a canned tune... And I pull 1 wheel on motor
On the 100 shot, I pick them both up... 6in or so, depending on how I choose to launch
This was with stock bullits on the front and a 235 60 15 dr on the back. Haven't beeb witg the draglites, 275 50 15s rear and 15x3.5s on the front, should be a little higher
Lotta suspension work tho
Do you still have a picture or two of those launches?
99GTvert is offline   Reply With Quote
Old 09-29-2009, 02:39 PM   #17
dimebag
2002 Ford Mustang
dimebag's Avatar
Vehicle: 02 gt
Send a message via AIM to dimebag Send a message via Yahoo to dimebag
Yea somewhere, ill try to post it up tn
dimebag is offline   Reply With Quote
Old 09-29-2009, 06:40 PM   #18
black35th
black35th's Avatar
Vehicle: '99 Mustang GT
Quote:
+1 to everything. Lifting the wheels is wasted energy.
__________________
Exhaust Clip
black35th is offline   Reply With Quote
Old 09-29-2009, 07:18 PM   #19
steve0914
steve0914's Avatar
i wanna see that 2ft trans am
__________________
2003 bolt-on GT- TOTALED
2006 F150 Chrome- New whip
steve0914 is offline   Reply With Quote
car, connecticut, end, forum, front, horsepower, hp, legal, lift, makes, mustang, street, turbo, twin, xpipe
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
