Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-28-2009, 08:13 PM   #1
a_penquin
1998 Ford Mustang
Vehicle: 1998 Ford Mustang GT
Send a message via AIM to a_penquin Send a message via MSN to a_penquin Send a message via Yahoo to a_penquin Send a message via Skype™ to a_penquin
Default DIY- tail light tint (sheet style)
Well I got my tint in and finally got some time to do the job, figure I'd give everyone a write up as well. The vehicle- 98 GT, just about impossible to find stock style tinted tail lights, so I made my own. You can buy a normal sheet, or pre cut like I did. Here is a link for the 94-98 ebay tint I used. http://cgi.ebay.com/ebaymotors/ws/eB...category=38661
Parts needed:
tint
soapy water
tail lights
water
spray bottle(s)
Tools:
11mm deep socket & ratchet or wrench
phillips (cross tip) screwdriver
heat gun
bondo scraper
mirco fiber towel
razor blade
Step one: remove tail lights.
Remove two plastic plugs holding in the trunk panels by the tail lights (one is removed with a screwdriver)
Remove four nuts holding the taillights in, then pull away from body and disconnect the light sockets from the light housing.
Tearing down the light....
Remove three screws from the bottom of the light divider,
then release three clips from the top
NOTE: weatherstrip seal may stick, carefully separate trim from housing with razor blade.
Wash taillight thoroughly with a sponge and dish soap, let dry or wipe with micro fiber towel.
(I got lazy here and too focused on working the sheet to take pics, sorry)
WARNING!: This is where it counts, take your time and take it slow, if it looks jacked up it will be jacked up!
Spray section to be worked with soapy water from spray bottle, then apply the sheet section to the light. Line up tint with even edges all around then take your scraper (wrapped in microfiber) and squeeze the soapy water out from under the tint. Now you should have it sticking in the center. Apply light heat (my gun was on the low setting about 6-8" from the light) and work out the bubbles and wrinkles (remove the heat when working the tint). Use your fingers to work the edges and take your time to smooth it out. Apply heat when needed. Finish each section in this manner.
Reassemble lights and reinstall. Your finished with some nice tinted tails! (hopefully) Step back and look at your work and enjoy the pride you did it yourself and didnt resort to euro's or azzeta's
Making the microfiber squeegee
Lay bondo squeegee in microfiber towel and wrap, that easy
__________________
98 4.6 SOHC GT
MSD coil packs, Headman street headers, BBK X-pipe w/cats, Cherry Bomb vortex cat back, ZOOM clutch, Auto Meter 3 pillar w/oil press, water temp, and volt gauges, Alpine head unit. work still in progress.
a_penquin is offline   Reply With Quote
Old 09-28-2009, 08:24 PM   #2
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
Vehicle: Stock 96 GT
Send a message via AIM to sxynerd Send a message via Yahoo to sxynerd
Quote:
Because they never made a factory tinted tail light.
sxynerd is offline   Reply With Quote
Old 09-28-2009, 08:28 PM   #3
a_penquin
1998 Ford Mustang
Yea, I know the factory never made one, but over the years you figure they should have an aftermarket one by now. Guess demand is to low, so I made due.
__________________
98 4.6 SOHC GT
Old 09-28-2009, 08:37 PM   #4
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
What did you do about the curvature of the lens? If you went over the edge, it's going to start to peel?. Did you cut and trim the edges to not overlap?
Old 09-28-2009, 09:04 PM   #5
a_penquin
1998 Ford Mustang
It was pre cut to the separate lenses, little heat, time, patience, stretching and finger work got it over the edges. No pieces overlapped each other. It also had an adhesive backing so as long as you get all the water/soap out from under it, it sticks and wont peel if everything is down flat.
__________________
98 4.6 SOHC GT
Old 09-28-2009, 09:11 PM   #6
945LSTANG
945LSTANG's Avatar
Vehicle: 2003 SVT Cobra
looks good minus the bezels. those things need a respray bad.
__________________
03 Cobra
94 GT - R.I.P. 11/30/08
Quote:
Originally Posted by casper_stang View Post
take in consideration the area where you live. where i live all cobras get stolen thats why i bought the GT
945LSTANG is offline   Reply With Quote
Old 09-28-2009, 09:14 PM   #7
a_penquin
1998 Ford Mustang
So dose the hole car lol, I still have the front right fender coming in black primer, and a cowl hood in white jell coat. A repaint is in its near future.
__________________
98 4.6 SOHC GT
Old 09-28-2009, 09:31 PM   #8
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
No mater how hard I try I haven't ever been able to do tint right.
Old 09-28-2009, 09:35 PM   #9
945LSTANG
945LSTANG's Avatar
i feel ya man.
the bezels on my 94 looked the same. hell, the whole car was riddled with random rock chips. one thing i do miss about crap paint is my lack of worry with it. the 03 has PERFECT paint and i poop myself everytime i hear rocks or other debris hitting my car.
__________________
03 Cobra
Old 09-28-2009, 09:49 PM   #10
Brute03
Brute03's Avatar
Vehicle: 2003 Mustang GT
so is that vinyl or regular window tint?
__________________
2003 True Blue GT 5spd
-UPR x-pipe
-Flowmaster cat back
-Cobra Brakes
-Sniper tuned
Home-made mil's
Brute03 is offline   Reply With Quote
diy, ga, light, lights, mustang, pics, rear, remove, sheet, spray, tail, tailight, tint, tinted, tinting
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
