Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-29-2009, 01:34 AM   #11
0949er
Vehicle: 2004 Mustang GT
well have you located the source at least? do you know if its coming from under the hood or under the car?
__________________
MODS:
Comp Cam Stage 2's (XE 270AH)
BBK LT's
MAC O/R Prochamber
Borla Stingers
JLT Cold Air
4:10's
288 wrhp / 310 wrtq (Tune by Pro-Dyno.net)
"Supercharger Turbonator Stage 2"
NEW VIDEOS!!!
In Progress:
Vortech V-1 T-Trim 60% Parts, 0% Install
0949er is offline   Reply With Quote
Old 09-29-2009, 01:53 AM   #12
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
Vehicle: Stock 96 GT
Send a message via AIM to sxynerd Send a message via Yahoo to sxynerd
My header was vibrating on my starter. I had to loosen up my H pipe and "wiggle" my exhaust around then re tighten and it went away. (Worse case scenario, you dimple the contact tube.)
sxynerd is offline   Reply With Quote
Old 09-29-2009, 10:15 AM   #13
PaintballFreak
PaintballFreak's Avatar
Vehicle: 2004, Mach 1
Quote:
When you say "wiggle", how much movement can you actually get from the header while it's bolted to the head?
If it is rubbing against something that would fit the rattle description - but what it's rubbing, I don't know. I hope it's something easy like the cross-brace on the K-member and not the K-member itself or the starter. It feels like it's on the drivers side but I could be wrong. I'll try to get under there and have a look around this evening. Thanks for the idea.
__________________
1999 GT - SOLD
2004 Mach 1 - Azure Blue
BBK Long Tubes - MAC O/R Prochamber - Borla Stingers
4.10s - Sniper Tuned
PaintballFreak is offline   Reply With Quote
Old 09-29-2009, 10:32 AM   #14
Tim99GT
1999 Ford Mustang
Tim99GT's Avatar
Vehicle: 1999 Mustang GT
So what i gather is that it even rattles when in idle? Have you put the car on jack stands, started it, and crawled under to see if you can better locate where it is comming from?
My guess is going to be the headers touching the steering shaft.
The tick is a exhaust leak...
What did your motor mounts look like when you did the header install? Might be a bit worn? causing the motor to move just a hair more than it normally does causeing the headers to rattle into something?
__________________
KENNE BELL 2.1L = SOLD
KENNE BELL 2.8H = Waiting to be installed
Aftermarket parts for sale - http://mustangforums.com/forum/new-e...ts-4-sale.html
Tim99GT is offline   Reply With Quote
Old 09-29-2009, 10:50 AM   #15
PaintballFreak
It's not the steering shaft, because I can feel it better through the floor/pedals than the steering wheel. It does it both during idle and when driving but it doesn't do it constantly. It comes and goes which is weird.
The mounts looked fine but I'm sure taking them on and off they are not in the exact position they were before. Like I said, they are on correctly and lined up with the K-member holes. So if it IS off, it is only by millimeters.
I have not put the car up on stands yet because it didn't really start rattling until an hour into my drive back to Austin. I don't have a good place to jack it up until maybe the weekend. Until then, unless I can poke my head under and feel it, I'm just going to make a list of things to look at.
__________________
1999 GT - SOLD
Old 09-29-2009, 12:42 PM   #16
PaintballFreak
FIXED!
Thank God it WAS the cross-brace that was causing the problem. Damn driver's side was resting right on the ****er. Sorry for wasting everyone's time - I could see it laying down beside my car. I crawled under to make sure there weren't any other issues, snapped some pics, and removed the brace.
Obviously the brace is important or it wouldn't be on the car. So should I get some washers to stick between it and the K-member to lower it a half inch or so? If not what's a good way to make sure it clears? It seems like it might be hard to dent and I'd rather not start swinging at the headers while they are on the car.
I was too busy smiling and pissing off all the students walking around me to think to put my window up and see if it was still making the tick-tick-tick which I thought was the midpipe. I'll check that later. I'll try to get up a sound clip some time. I only have a regular camera and the sound quality for the video sucks.
For now, more PICS:
__________________
1999 GT - SOLD
Old 09-29-2009, 02:06 PM   #17
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
The brace isn't that important, lol. Nothing some subframe connectors can't fix anyway. I you really want it there, you can use some big washers and a pipe (Cut the pipe to length) to lower down the brace a little. Or just use washers. I did that with my 03's GMS K member & brace..
2000, 2004, exhaust, firebird, firebirds, fix, header, headers, leak, long, mach, mustangforums, noise, pipes, rattle, tubes
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
