Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-05-2009, 09:08 PM   #21
0949er
Vehicle: 2004 Mustang GT
well the way I think about it... whats the WORST that could happen? I need to have it re-build by vortech? (still under the cost of buying a brand new head-unit)
+ I am getting a intercooler setup
+ i am getting a set of 8 42lb injectors
with about $800 to spare (based off buying a brand new head unit)
__________________
MODS:
Comp Cam Stage 2's (XE 270AH)
BBK LT's
MAC O/R Prochamber
Borla Stingers
JLT Cold Air
4:10's
288 wrhp / 310 wrtq (Tune by Pro-Dyno.net)
"Supercharger Turbonator Stage 2"
NEW VIDEOS!!!
In Progress:
Vortech V-1 T-Trim 60% Parts, 0% Install
0949er is offline   Reply With Quote
Old 10-05-2009, 09:09 PM   #22
0949er
sorry, double post
__________________
MODS:
BBK LT's
MAC O/R Prochamber
Borla Stingers
JLT Cold Air
4:10's
NEW VIDEOS!!!
In Progress:
Old 10-06-2009, 01:34 AM   #23
0949er
ok deals done.
Vortech v-1 T-trim
intercooler (and everything)
fuel injectors
$1650 (includes shipping)
__________________
MODS:
BBK LT's
MAC O/R Prochamber
Borla Stingers
JLT Cold Air
4:10's
NEW VIDEOS!!!
In Progress:
Old 10-06-2009, 01:42 AM   #24
Eduardo
2004 Ford Mustang
Eduardo's Avatar
Quote:
Originally Posted by 0949er View Post
ok deals done.
Vortech v-1 T-trim
fuel injectors
you're also going to have to have some welding done with that DIY intercooler kit. you're going to need to weld a bung for the IAC valve and either a bung or flange for your BPV.
__________________
Eduardo is offline   Reply With Quote
Old 10-06-2009, 02:03 AM   #25
0949er
Quote:
ok. can you explain to me in a little more detail?
I know the intercooler side needs a blow-off valve, will that in "in-line" with the piping, or does it split off the pipe somewhere to make a T or something. Also, what do I need to connect to the IAC? Haha sorry its my first time ;-) Thanks for the help guys.
__________________
MODS:
BBK LT's
MAC O/R Prochamber
Borla Stingers
JLT Cold Air
4:10's
NEW VIDEOS!!!
In Progress:
Old 10-06-2009, 02:13 AM   #26
Eduardo
2004 Ford Mustang
Eduardo's Avatar
well if you go with the stock BPV all you need is a bung welded then you can attach the BPV with heater hose. if you get a mini race bypass(reccomend it for more than 8psi) then you need a flange welded onto the piping. heres a pic of my engine bay:
see that hose, it is connected to a 3/4" piece of aluminum pipe that i had my buddy weld then i painted it
here is my BPV(mini race BPV) flange welded to the piping...keep in mind this is with a blow through setup. you havent said whether you're doing a blow through or draw through.
__________________
Old 10-06-2009, 02:15 AM   #27
sxynerd
1996 Ford Mustang
My Garage
sxynerd's Avatar
Vehicle: Stock 96 GT
Send a message via AIM to sxynerd Send a message via Yahoo to sxynerd
they sell couplers on ebay with the bungs. draw through?
sxynerd is offline   Reply With Quote
Old 10-06-2009, 02:18 AM   #28
Eduardo
2004 Ford Mustang
Eduardo's Avatar
Quote:
never seen those before, draw through - maf before blower
__________________
Old 10-06-2009, 09:12 AM   #29
amoosenamedhank
amoosenamedhank's Avatar
Vehicle: 1996 GT
Here is an idea of what a draw through setup looks like. The MAF is in the fenderwell with the filter and the BPV is located in the discharge tube.
__________________
amoosenamedhank is offline   Reply With Quote
Old 10-06-2009, 11:08 AM   #30
0949er
I though that with a intercooled setup you use a blow-thru and with a non-intercooled setup you use draw-thru?
Where can I look into getting a bypass valve? I assume that the guys has these pipes welded in already, since he was using it on his mustang before (and it was working) I will simply need to buy the hose and bypass valve.
__________________
MODS:
BBK LT's
MAC O/R Prochamber
Borla Stingers
JLT Cold Air
4:10's
NEW VIDEOS!!!
In Progress:
2v, belt, body, change, fox, install, intercooler, kit, mini, numbers, race, rebuild, serial, v1, vortech
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
