How to: Install HIDs
#21
care to elaborate on that? they either change voltage or amperage going through the bulb, i just can't remember which. either way, the result is that the arc moves in an uncontroled manner to "move" the light source, creating a high beam effect. unless you get an even worse kit, the kind that has 2 HID bulbs bashed together to fit in a housing not meant for it.
http://www.danielsternlighting.com/t...nversions.html
#22
-came with no instructions
-came with no proper mating connector to the stock wiring it appears as well
-also, it should be noted that it is kit comprised of a 50w ballast and 35w bulbs, its not really a 55w kit and will run hotter, not to mention have a shorter life span
nice write up on the install though
Halo lights look reduculous on a new edge. That's why I don't run them and will never run them on my car.
#23
And yes, dual arc bulbs exist, however just like bulbs with piggy-backed halogen bulbs, they refract the low beam output making the low beam output even worse.
There are HID experts on this site, and we get a lot of questions everyday that have no basis in reality, all myths perpetuated by those that talk quite frankly out of their rear ends. So yes, when incorrect information surfaces we will take aim to correct it before accepted as "fact."
#24
most hid kits come with less work then those anyways. every kit i bought.. Plug in the stock harness to the ballist> ballist to bulbs and bulb goes into the headlight ur done. imo u dont really need dual beam hids. low beam are bright enough anyways..
#25
The low beam mustang lamps run off PWM (pulsed 12vdc ), so a kit with direct plug and play operation will result in the lights not working properly (flickering or shutting off) or premature end to the ballast lifespan.
#27
I'm sorry, my apologies, your model year is before the PWM. Only the 05+ using H13 function in that manner. Yours still gets a constant 12v+
#28
np.. wasnt bad mouthing ur product.. was just saying how some of the kits come.. ya i was amazed in general my kits have last 2 years seeing the stress there under lol
#29
I know you weren't, but I mis-spoke (or mis-typed rather) and it needed to be corrected to prevent confusion.
#30
I find that very hard to believe, because your statement before regarding a change in amperage was completely inaccurate. So well versed you may think you are what you are saying was in fact wrong. If you knew you wouldn't have posted that, and then a reference to another website that does accurately describe function but not in the manner you described. Either you had no idea what you were talking about, or you didn't read what you quoted closely enough to understand it, or both.
i don't really want to get into an e-pissing match with anyone, just like people to be informed. it seems that a lot of people just throw these things on without really knowing what it is they're doing to themselves and to other drivers. case in point the post asking why they're bad. in any event, no hard feelings towards anyone
mungodrums
10-07-2015 04:01 AM
M3hunter
09-05-2015 03:42 PM
