aight so right now everything on my stang is stock as can be but i cant figure out exactly what it is for some reason when i start the car and for a while after that something is not telling my car when to idle and the rpms will just just keep dropping until my engine turns off. the only time it stops is after a while of driving. wtf?!
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Try cleaning your maf, iac, check air filter. Then come back to us if that does not work or help. And check for any vacuum leaks also.
__________________
03 silver v6 coupe auto. Gets me from A to B.
1999 mustang gt 5spd: ford racing t-loc with carbon disc's(31 spline), 31 spline axles, 3.73's, Dr. Gas x pipe, mac cat-back, drop in K&N filter, livewire tuner, strange 10 way adj shocks, a shorty antenna, and i need more!!
You can also try the reset the KAM by disconnecting your battery for 10 mins or so. This will force the car to relearn the idle etc. Make sure you let the car idle for a bit after you turn the car on, do not hit the gas. This is the first thing I would try then the things above.
__________________
2002 GT Vert.
Bassani Mid-Length Headers
Bassani X-Pipe
Bassani Catback
Pro-5.0
FR 3.73
Professional Products 75 tb and plenum
JLT Ram Air
Sniper DF Custom Tune
