Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-26-2009, 12:12 PM   #11
IEC Stang
If u want more volume i'd go with slp lm1 or slp lm2. i would change out the catback before id change the midpipe because the midpipe is a pita to take off and put back on unless u have a lift but even then i still wouldn't touch the mid pipe ne more.
IEC Stang is offline   Reply With Quote
Old 10-26-2009, 01:32 PM   #12
snu00GT
Vehicle: 2000, GT, Mustang
i would just keep things as is and change the catback to a set of stingers or magnapacks but the issue is i've already got an expensive high flow catback system on there can can't afford to replace it. cutting off the cats just seemed like an ok idea because its cheap and i've found a few places to make my own simulators.
what would be the difference in buying the 'off road x pipe' and just cutting off the cats with the current x pipe?
snu00GT is offline   Reply With Quote
Old 10-26-2009, 05:29 PM   #13
98redstang
1998 Ford Mustang
Vehicle: 1998, Ford Mustang
Youd just be saving some money. If the work of cutting and welding is easy for you than go for it thats what i did. I just chopped my stock h pipe (which needed to be shorter anyway to match up with the lts) and welded the flanges back on and it was perfect for me. But if you dont have easy access or the ability to do the work than just buy a o/r x. I would try and look for a used one. Ive seem some floating around for at least half the price of a new one.
__________________
Motor by bumpperformance.com:
npi block compression 10.6:1
stage I ported pi heads/stage I comp cams/PI intake/24# injectors
Cobra oil pump/High output water pump/Mac UD Pullies
Exhaust/Intake:
MAC LT headers/O/r H-pipe/American Thunder catback
p&p tb-pl/C&L cai
Drivetrain:
King Cobra Clutch/Motive 4.10's/Steeda Pro 5.0
Suspension/Tires:
Black cobra r 275/40
Conservative 87/89 Dyno
290rwhp 320rwtq
Next up:
Upr+lwr Control arms & subframe connectors
98redstang is offline   Reply With Quote
Old 10-26-2009, 08:38 PM   #14
steve0914
steve0914's Avatar
are your cats held on by clamps or welded? mine were clamps and i could pull them off and clamp in a larger tube.
__________________
2003 bolt-on GT- TOTALED
2006 F150 Chrome- New whip
steve0914 is offline   Reply With Quote
Old 10-27-2009, 12:27 PM   #15
snu00GT
good question? i'll look today and see but i think they are welded in
05, borla, cats, exhaust, extreme, gt, hpipe, inspection, mustang, nj, offroad, paired, pass, removing, roush
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
