This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
A.S.E. Master Tech, Ford Factory Trained Tech, and SVT Trained Tech
D.S.S. 5.1 stroker built by ProLine Race Engines, 200 shot, TCI 4r70w trans, 3200 stall, trick flo heads, stage 2 cms cams, Long tubes, o/r h-pipe, flows, eibach pro-kit, 4.10 gear, 03 cobra deep dish in black, tuned by Tim Barth at Modular Power House
The fundamental question that needs to be asked here is what are the drivers needs. If the OP wants a very good tire, the Jmac beat me to it and the Khumo's for dry/cornering performance fo sho!
If after good performance tire at what is probably a cheaper price and longer life expectancy, go 555's
Def the Kumhos. I have Nitto 555's and I just can't hook with these period. Straight line or corning. Heating them up or not, Changing tire pressure, street or track, etc... just won't happen. I will never be buying 555's again. I will say one thing tho, they do last a long time.
__________________
FRPP 4.10 Gears, Moser 31 Spline Axles, Auburn Pro Series Differential
SLP Loudmouth II w/MAC O/R Prochamber H Pipe, FRPP Aluminum Driveshaft
Saleen Wheels w/Nitto NT555 Tires, JLT True CAI, BBK 75MM TB
SCT Livewire Tuner, SLP Line Lock, Tein S-Tech Springs, Steeda Tri-Ax
244.1 RWHP 275.3 RWTQ
Waiting to Be Installed Fox Lake P-51 Black Powdercoated Intake Manifold, SCT 90MM MAF, Corbeau Harness Bar
A couple months ago there was a thread like this and everyone was saying NT555's were really good that's why I went with them now it's Kuhmos?
__________________
2000 Ford Mustang GT
Vortech V1 S Trim
JE 194329 Forged Pistons
CRS 5933F30 Forged Rods
Fel-Pro Gaskets & Bolts
Ford Racing 11" Clutch
Sniper Tuned
Pypes Violators
Mac Prochamber
B&M Shifter
Subframe Connectors
^ just a comparison between those particular tires.
You will ALWAYS find a preferable tire, depending on the $$$ you want to spend and the performance you require. I haven't checked the prices, but figure the Kumho's are more expensive.
yo ive used both and i'd say falken 542. there exactly like the nt555 but i felt like the 452's just lasted a little longer and had pretty god grip once warmed up.
__________________
SCCA/NASA 98 GT max1.2g track suspension, and minor bolt-ons(Drift/Drag/Grip)
1969 fastback 351w
1970 mach 1 315c
1967 Camaro 350
