Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-20-2009, 08:49 PM   #1
nagata
nagata's Avatar
Vehicle: 96 GT w/ PI swap
Cool Well SOB, rear diff seal leaking...And the money pit that will be the Mustang starts
Noticed a spot on the driveway this afternoon, looked under the Mustang, and sure enough, it's dripping a bit of fluid in the middle of the diff. I definitely checked the diff before buying the car, and it wasn't leaking. Not sure why it's started to leak, but the seal *should* only be about 1.5 years old, as the gears were replaced in the summer of 08 (have the receipt).
Is this a common thing? I could probably put on a new seal myself, but I'm gonna give a local guy who is REALLY good (and low priced) on rear ends a call tomorrow and see what he'd charge me. At least if I have him do it, he could look at the rear end in general and tell me if there's anything else wrong with it. If nothing else, I'll make sure the fluid is okay and put on a new seal this winter.
Anything odd about these diffs that I should be aware of? I know if I've got the stock trac-lok, I would need to add friction modifier.
__________________
96 GT, blue, 5-speed, stock exterior w/ 17" OEM wheels, purchased 10/17/09 w/63k miles.
Go-Fast Goodies: Full PI swap w/ 3 angle grind, +1mm Ferrera valves, & Comp Cams valve springs, Comp 262 cams, FIPK 2, Accufab 75mm, C&L upper, BBK LT, BBK X-pipe, Magnaflows, FMS 4.10s, and MGW STS.
Custom Dyno tune results: 300 HP@5600 rpm, 320 TQ@4000 rpm.
Exterior and suspension improvements to come...
nagata is online now   Reply With Quote
Old 10-20-2009, 09:05 PM   #2
LIKESITRIGHT
LIKESITRIGHT's Avatar
Vehicle: 05 SATIN SILVER FORD MUSTANG GT
mine just started leaking too. i changed the diff fluid ( royal purple) about a month ago, and a week ago noticed the drips on the floor. what is involved in replacing the front seal, do you have to remove the insides ( ring and pinion) or can it be done from outside the rear end?? what is a good price to have this done??
__________________
2005 Satin Silver Gt , Eibach Prokit , Magnaflows, o/r h pipe, 4:10 gears, steeda cai, xct3 ,93 brenspeed tune, mgw shifter, painted stripes, gt 500 splitter.
LIKESITRIGHT is offline   Reply With Quote
Old 10-20-2009, 09:06 PM   #3
dimebag
2002 Ford Mustang
dimebag's Avatar
Vehicle: 02 gt
Send a message via AIM to dimebag Send a message via Yahoo to dimebag
Dude, do it yourself. Unbolt it, scrape the cover and diff. Apply rtv, put cover back on... Refill diff
dimebag is offline   Reply With Quote
Old 10-20-2009, 09:12 PM   #4
99mustanggt
Vehicle: 99 Mustang GT
I beleive he is referring to the pinion seal not the cover.You dont have to remove the insides but you have to make sure the nut gets tightened exactly to where it was so you dont have to much preload.
__________________
CMS stage 2's,comp springs,and Bullitt intake waiting for install.
Looking for focus fuel pump and ported heads.PM me if you have any.
99mustanggt is offline   Reply With Quote
Old 10-20-2009, 09:15 PM   #5
LIKESITRIGHT
yes ,mine is the pinion seal.
is there a write up on this anywhere on the net that you know of?
__________________
Old 10-20-2009, 09:21 PM   #6
99mustanggt
Not that i know of.Unhook driveshaft,measure turning torque with beam still torque wrench,mark nut with whiteout,loosen nut with impact,use puller to get yoke off,pop out seal,install new seal,put yoke on,install nut very slowly until original turning torque is reached,add driveshaft,check fluid.Theres a short version.
__________________
Old 10-20-2009, 11:39 PM   #7
nagata
nagata's Avatar
Quote:
Well, I'm certainly not afraid to do it, but I may take it to this mechanic (he's done diff work for me twice before, great guy) just to get his input on the internals of the rear, make sure everything is in good shape and I don't have to worry about bigger problems. I suppose I could do some research and try to check it over myself, but I'm still no expert. I'll see what he tells me.
__________________
Old 10-26-2009, 12:16 AM   #8
nagata
nagata's Avatar
I went ahead and replaced the fluid/resealed the rear cover myself. Took friggin forever because I kept running into little snags, but it's done! Used RTV gasket maker and refilled the diff with Mobil 1 Synthetic 75w-90 and 4 oz of modifier. Most time consuming part was refilling the pumpkin, it was an absolute PITA, ended up getting a hand pump to do it.
Everything inside looked great, so hopefully the diff won't give me any further problems *knock on wood*
__________________
1999, diff, differential, fluid, gt, input, leaking, mustang, rear, seal
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
