Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-31-2009, 09:35 PM   #1
narib2008
Vehicle: 1997
Default 97 GT Coolant Temp Gauge on low side
Hey Guys,
I purchased my 97 gt about a month ago.Ever since i have gotten the car i have tryed to figure out what is with my coolant temp gauge.The gauge when driving normally only reads about 1/4 of the way.However if you let the car sit...it seems to eventually get up to the 1/2 way mark.I replaced the thermostat originally because it sounded like a thermostat issue.However it did not make a difference.Thinking maybe i got a "bad" new thermostat.I removed it today and put it in water to test it out.It opened at 195 and closed at about 185.This is pretty much right on target for a new stock thermostat.So i ruled that out.I was wondering what you guys could think it could be otherwise.I found out by playing with the two coolant temp sensors the one on the drivers side seems to be used to control a/f ratio's and send a signal to the ECU???While the one on the passenger seems to send a signal to the gauge?Anyone have any idea on how to test these sensor's?Maybe the resistance they are suppose to be when functioning properly?Or could it be another issue?Thanks
narib2008 is offline   Reply With Quote
Old 11-01-2009, 09:51 AM   #2
Chris98Gt
Chris98Gt's Avatar
Vehicle: 98 Mustang Gt
What do you expect to happen, when your driving you've got that extra cooling effect so it'll run cooler, when sitting theres no extra air flow till the fan comes on. Sounds like its working fine to me.
__________________
98Gt with pro 5.0shifter, 3.73's Pi swap and stage 2 CompCams, BBK Lt's, catless H pipe, Flows. Procharged 8psi
Chris98Gt is offline   Reply With Quote
Old 11-01-2009, 10:19 AM   #3
Lowtryx
1996 Ford Mustang
Lowtryx's Avatar
Vehicle: 96 GT
Yeah, honestly it doesn't really sound like you have a problem. You have heat, and it's on the low side. Frankly, it sounds quite efficient? :P
Is your coolant level up to your cold fill mark?
__________________
Red 1996 GT
PI Swapped
BBK Shorty Headers
Pypes HFC'd X Pipe
Magnaflow Catback
Fender-Well CAI
Hurst Billet Aluminum Shifter
Rear Window Louver
Drilled/Slotted Rotors with High Perf. Pads
Hood Pins!
Sequential Tail Lights
Awful Looking Stock Rims Painted Gun-Metal
Lowtryx is offline   Reply With Quote
Old 11-01-2009, 10:41 AM   #4
narib2008
Vehicle: 1997
Yes im not loosing any coolant and i have heat.No problem there.Im just worried that im running a little rich and the car is not getting the best gas mileage it could be.When driving the needle on the gauge goes to about "N" or "O" on the "NORMAL" indicator.I noticed in my 96 gt it pretty much stayed
at the "M" all the time.I just jumped my sending unit harness and the mechanical gauge inside the cluster seems to be functioning properly.Im gonna data log the coolant temp tommarow and see how it fluctuates.Im probably just being to anal about it(and ford probably uses a crappy gauge with a real time rheostat instead of a more modern average rheostat(like gas gauges use)
Old 11-03-2009, 03:44 PM   #5
ESABATM
Vehicle: 2000 Mustand Gt
Change the sending unit. Some sending units on the 4.6 in the mid 90's weren't up to par. I had a 95 T-Bird with the same issue. Changed the sending unit with a new Ford unit problem fixed.
That sending unit has nothing to do with the fuel IIRC.
ESABATM is offline   Reply With Quote
Old 11-03-2009, 08:33 PM   #6
97gold
Vehicle: 97 ford mustang
mine does it and i have a 03 engine in mine
97gold is offline   Reply With Quote
2005, 46, 97, car, coolant, gauge, gt, high, immediately, mustang, stock, tank, temperature, thermostat, turning
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
