Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-02-2009, 02:52 AM   #1
darkmach1
darkmach1's Avatar
Default Need some wheel/tire input!!!
I'm looking into getting some 17x10 cobra wheels with some 26x11.5x17 ET streets on them. The seller has used these wheels on his s197 numerous times and says one wheels is slightly bent but its not serious. Would it be a good idea for me to get these? Its gonna be only for track use.
__________________
Mods: C&L intake, Mac prochamber, Moser 31 spline axles, FRPP trac-lok, FRPP 4.10s, Steeda Tri-ax short shifter, SSS catback, PHP 3/8 intake spacer, VMP custom tune(SCT).
....I foresee a squeaky belt in my future.....
darkmach1 is offline   Reply With Quote
Old 11-02-2009, 08:09 AM   #2
99 GT vert
99 GT vert's Avatar
Vehicle: 1999, Ford, Mustang
Send a message via AIM to 99 GT vert
get pictures of the bend and if it is bad i would pass but if it is a slight bend i wouldnt worry about it
__________________
99 GT vert is offline   Reply With Quote
Old 11-02-2009, 12:00 PM   #3
darkmach1
darkmach1's Avatar
Not sure if its even noticeable, here are pics even though Im not sure you'll be able to see them, it might ask you to log on.
http://www.stangsofsouthflorida.com/...ead.php?t=9546
__________________
Old 11-02-2009, 12:02 PM   #4
99 GT vert
99 GT vert's Avatar
yea you have to log in
__________________
Old 11-02-2009, 12:10 PM   #5
darkmach1
darkmach1's Avatar
Hold on he emailed some pics.
__________________
Old 11-02-2009, 12:20 PM   #6
darkmach1
darkmach1's Avatar
Here they are....
__________________
Old 11-02-2009, 01:03 PM   #7
RogerDodger1
Vehicle: 1989 Piece of Junk
Unfortunately, no way to tell how much a bent wheel will affect the balance of the wheel and tire assembly and cause a vibration or not just by looking at a picture. To find out how bad the bend is, I recommend taking it to a tire shop and having the bent wheel spun on a wheel balance machine to see what you are getting into before you lay out your cash. The bend can be measured with a radial run out gauge while on the wheel balance machine to see if it is within tolerances. .50 out of round is the maximum.
RogerDodger1 is offline   Reply With Quote
Old 11-02-2009, 01:11 PM   #8
darkmach1
darkmach1's Avatar
Quote:
So .50 is the max. anything below that is OK to drive? Are you sure about that number?
__________________
Old 11-02-2009, 01:15 PM   #9
RogerDodger1
Quote:
The tire shop can verify it for you with the radial run out gauge, assuming they have one and know how to use it. Call around to different shops and ask before showing up. You'd be surprised with how many shops don't even know what a radial run out gauge even is. Better tire shops will have a road force balancing machine that can also check the rim. Again, just call around and ask.
My suspicion is the wheels are being sold because of the bent rim causing problems. Remember, it was only driven by a little old lady on Sunday's. R-I-G-H-T. Good luck with it.
Old 11-02-2009, 01:18 PM   #10
darkmach1
darkmach1's Avatar
LOL. Well he "says" he purchased them bent and has dozens of track runs with them, he's going with a differen setup now, but I'll take your advice, thanks.
__________________
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
