Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-04-2009, 12:05 PM   #11
fordmuscle
Vehicle: 98, Mustang
Default spark plugs
I would have to agree just use the Motor Craft Plugs. That way if you have any type of problem you can go to a local parts store and fix it.
fordmuscle is offline   Reply With Quote
Old 11-04-2009, 02:42 PM   #12
03BottleFedGT
03BottleFedGT's Avatar
Vehicle: 03 GT, 68 Coupe,
autolight ap104 same as motorcraft and has longer threads reduces chance for blowout
__________________
A.S.E. Master Tech, Ford Factory Trained Tech, and SVT Trained Tech
D.S.S. 5.1 stroker built by ProLine Race Engines, 200 shot, TCI 4r70w trans, 3200 stall, trick flo heads, stage 2 cms cams, Long tubes, o/r h-pipe, flows, eibach pro-kit, 4.10 gear, 03 cobra deep dish in black, tuned by Tim Barth at Modular Power House
03BottleFedGT is offline   Reply With Quote
Old 11-04-2009, 03:43 PM   #13
99BlackPonyGT
aka Negative Nancy
Vehicle: 1999 Mustang GT
Send a message via AIM to 99BlackPonyGT
the threads in the head are the problem, not the spark plug.....just sayin
99BlackPonyGT is online now   Reply With Quote
Old 11-04-2009, 09:16 PM   #14
stang315hp
Vehicle: 2003 Mustang Gt SOHC (unfortunately)
Default blowout
Quote:
Thanks for the help, what do you mean blowout? What's the best way to get 20hp more out of this car? Thanks again.
stang315hp is offline   Reply With Quote
Old 11-05-2009, 07:50 AM   #15
MJH78
Quote:
Some of these modular engines during certain model years are known to "spit" plugs out because of a lack of sufficient threads in the head for the spark plug. On your other question, most people will recommend upgrading your ring and pinion gears to a 3.73 or 4.10 and getting a tune.
__________________
2000 GT 5spd, MAC SS Catback, JLT RAI, MGW shifter, O/R Prochamber, FRPP 3.73s, Sniper SF 91 tune, Trickflow plenum.
MJH78 is offline   Reply With Quote
Old 11-06-2009, 09:15 AM   #16
stang315hp
Default respond
Quote:
I already have a chip and tune, but what about underdrive pulley's? (my crankshaft one is rusted anyway) I still think though that better plugs should give a better spark even if it's avery small difference it''s still a difference is it not? In this regard, which one's would you pick. (blow-out safe) THANK GUYS.
Old 11-06-2009, 10:01 AM   #17
MJH78
There's no "blow-out safe" spark plug. A motorcraft plug is all you need, but if you feel you need something different, go right ahead and waste your money. What is it you want from the car and how much money do you have budgeted? Underdrive pulleys are not your answer for performance gains.
__________________
4041, 46, 493, 97, bosch, ford, forum, motorcraft, mustang, ngk, plug, plugs, sp, spark, spark plug, spark plug help
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
