Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-02-2009, 09:15 PM   #1
stang315hp
Vehicle: 2003 Mustang Gt SOHC (unfortunately)
Post Best Spark Plugs - Please help
I really like the PULSTAR plugs that I've been checking out but I want too make sure that it's the right choice, I don't want too stay stock because of several reasons, at least an iridium upgrade is my choice. I just want too make sure that the heat range problem won't be there, what's the motorcraft (I think it's 32) heat range compare too the NGK? And should I gap whichever plug? I'm looking for the best performance/better fuel economy boost, but I want it too be safe. I really appreciate your help with this I'm an extremely in-decisive person. I have 30k on my 2003 GT, it's got 50hp added altogether so I shouldn't need a colder plug. (flowmaster, chip, k&n filter)
P.S. - money isn't an issue so the best of the best works, thanks again
stang315hp is offline   Reply With Quote
Old 11-02-2009, 09:47 PM   #2
stangalator
1997 Ford Mustang
stangalator's Avatar
Vehicle: 1997 Mustang GT
Send a message via AIM to stangalator
Pulstar's are a gimmick, just like the bosch +4 and others like that. The gt's don't respond great to ignition upgrades unless your F/I and your blowing out your spark. The stock gap is .054 plus or minus .002.
A CB, filter and tune wont net you 50 horses in a GT. More like 12-15 ish realistically... As for plugs most ppl here will say the stock motorcraft will be fine since copper is better conductor then platinum or iridium. The smaller tip is better on harder metals like the iridium ones because the spark is more precise then a copper one. However I've heard them being bad in F/I...
I bought some NGK XI plugs when i first bought my car for 60-70 dollars and they are not worth it (but if money is not really a probelm get them) and platinum is a waste imo. You can use that 60 dollars else were with better gains. Like a used O/R H pipe, those 4 cats you have on the car are holding you back more then you think.
__________________
PI swapped, LT's, O/R H, Pro 5.0, 24lb injectors, accufab 70mm TB, FRPP 4.10's & sniper SF
241/274
To Be Installed:
MMFLSFC
stangalator is offline   Reply With Quote
Old 11-02-2009, 10:18 PM   #3
hpwrestler220
hpwrestler220's Avatar
Vehicle: 2001
i bought stock oem motorcraft replacements for like $26 after the discount code from americanmuscle... can't go wrong...
gapped in between .053-.055..but they come pre-gapped. jsut double check to make sure
__________________
Things to do:
1) Fix exhaust leak
2) Remove isolators
3) Get rear decklid shaved and painted DONE
4) Get fog lights sprayed with black/clear mix
5) Get lower valence re-sprayed
So far, i'm 1/5....
hpwrestler220 is offline   Reply With Quote
Old 11-02-2009, 10:43 PM   #4
stang315hp
Thumbs up Thanks
Thanks, it's a shame you can't get reliable reports from these greedy companies, you've definitely turned me from the pulstar's. I was just worried about putting the motocraft's back in there, when I hear they were snapping off in the engine (going too use deep creep). Also, the sp-493 (standard) actually are platinum tipped. Thanks for the help.
P.S. Already have the H pipe, and your right.
Old 11-02-2009, 10:58 PM   #5
stang315hp
Exclamation ??
What did you mean by "unless you F/I and blowing out your spark"?
Thanks
Old 11-02-2009, 11:29 PM   #6
stangalator
1997 Ford Mustang
Under some cases with boost numbers the stock ignition system can't handle firing a complete combustion at high rpms. However with a N/A mustang you wont see much of an improvement over your stock COP's.
__________________
241/274
To Be Installed:
MMFLSFC
Old 11-04-2009, 09:36 AM   #7
stang315hp
Default ??
"N/A" and stock "COP's"? again I'm lost too what that means? Thank you. I guess I really wish too get some improved acceleration and mpg's out of SOME plug. (most people use NGK's) THANKS AGAIN WISE ONE.
Old 11-04-2009, 10:32 AM   #8
stang315hp
Default please
please give me some hope for improvement, thanks.
Old 11-04-2009, 10:50 AM   #9
MJH78
Just get the Motorcraft plugs, simple as that. That's all you need. Don't waste your money. You're not going to notice any difference between a Motorcraft plug and any other fancy plug on the market. It's just a plug..gap it to specs and put it in. And...you might have 10hp from a k&n, flowmaster, and a "chip"...not 50. Quit falling for all this marketing crap. I'm not trying to be harsh, just trying to give a little advice.
__________________
2000 GT 5spd, MAC SS Catback, JLT RAI, MGW shifter, O/R Prochamber, FRPP 3.73s, Sniper SF 91 tune, Trickflow plenum.
MJH78 is offline   Reply With Quote
Old 11-04-2009, 11:24 AM   #10
lizzyfan
Made Moderator
lizzyfan's Avatar
Vehicle: 98 GT Blumurder
Quote:
That's what I run with 14lbs of boost and no problems!
__________________
Tuned by Matt at Performance Evolution
432 rwhp
426 tq
DD-2008 Mazda3 Zoom Zoom!
1996-Ranger (AKA "Barney") RIP 305K!
lizzyfan is offline   Reply With Quote
4041, 46, 493, 97, bosch, ford, forum, motorcraft, mustang, ngk, plug, plugs, sp, spark, spark plug, spark plug help
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
